Can't decide on sub for car use - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 45 Old 08-16-14, 12:49 PM Thread Starter
sub_junkie's Avatar
Dylan
For a while, I had my two Q18's in an extended cab ranger running on 2200w. They were extremely held back by box size, I believe they were in a 4cu.ft tuned to 29hz, but there was a considerable amount of port compression. They still sounded fairly musical though.
I recently bought a Sundown X15 to go in the truck instead of the 18's. The sub sounds extremely musical and accurate, but the mid bass region is leaving lots to be desired (50hz and up). The sub is just EATING amp power above 50hz or so, and not creating much kick drum hits or anything of the sorts. The lows though...they're insane. 2-4 of the X18's in an LLT would be insane in a room... Anyways, my question is this. How can I improve "midbass" response in that range?
Currently the X15 is in a 3cu.ft tuned to 32hz, running on 2200w and taking it like a champ even though it's only rated for 1250w. Even with the highpass at 10hz on my amp, I can play any content at near clipping levels and still not reach xmax or much past it. (It's got 4" travel peak to peak so I'm not worried about that amount of power going to it lol)
I'm to the point where I'm considering returning it to SSA and see about exchanging it for a SSA Xcon 15...that driver seems like it would be capable of what I want to achieve. Plenty of xmax for the low content, relatively high sensitivity, I just haven't been able to throw it into WinISD yet to see how it compares to the X15 in there.
Any opinions on other drivers or box configurations are more than welcome. I can fit around 5.6cu.ft after port volume accounted for in the last box I built, the port was 7"x50" so I can fit a decent sized box in the truck. I really like how this sub sounds, I have not even two hours of play time on it so maybe once it breaks in more the bass region where it's lacking will pick up.
Build log:
sub_junkie is offline
post #2 of 45 Old 08-17-14, 05:48 AM
HTS Senior Moderator
chrapladm's Avatar
Papi
Re: Can't decide on sub for car use
Round......5.
I will get a simulation here soon. I have simulated the X series 15 a LOT. Will probably be my next subwoofer. Also going to be getting some 10" X series also. Just off the top of my head you wont be hitting Xmax until around 20 something Hz. You probably are going to hit Mechanical limits around 16 or so Hz. So try not to play many "chopped and screwed," tracks.
The hardest thing for me to do was to find a cabinet design that allowed me to have RMS power and hit Xmax. These subwoofer from Sundown are crazy. Hitting 30mm excursion takes a LOT of power. I looked at getting a NSv3 15" until I saw I would need something like 7000watts to just hit Xmax without a hpass at 10hz on a 18hz tune.
"Music is the space between the notes"
“[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.”
chrapladm is offline
post #3 of 45 Old 08-17-14, 10:32 AM Thread Starter
sub_junkie's Avatar
Dylan
chrapladm wrote: View Post
Round......5. I will get a simulation here soon. I have simulated the X series 15 a LOT. Will probably be my next subwoofer. Also going to be getting some 10" X series also. Just off the top of my head you wont be hitting Xmax until around 20 something Hz. You probably are going to hit Mechanical limits around 16 or so Hz. So try not to play many "chopped and screwed," tracks. The hardest thing for me to do was to find a cabinet design that allowed me to have RMS power and hit Xmax. These subwoofer from Sundown are crazy. Hitting 30mm excursion takes a LOT of power. I looked at getting a NSv3 15" until I saw I would need something like 7000watts to just hit Xmax without a hpass at 10hz on a 18hz tune.
I've played a 17hz song by bassotronics and I still have probably 2" of travel left. Lol. Now that it's breaking in its sounding a bit better but I'm still curious as to what my options would be for different box configurations or a different sub as well. I think this 15 could handle 3000w with ease lol. I'm not sure about how well it would be able to cool itself at that power but speaking in regards to excursion capabilities, 3k would be a walk in the park for it outside of WinISD's calculations
Build log:
post #4 of 45 Old 08-17-14, 05:58 PM
chrapladm's Avatar
Papi
I am curious if it is even getting 2000watts then. You should be breaking it at 16hz with 2000watts.
post #5 of 45 Old 08-17-14, 08:54 PM Thread Starter
sub_junkie's Avatar
Dylan
I'm thinking the amp doesn't have a true 10hz HPF, and with differences in box impedance it's probably not seeing a full 2200 at 16hz and below. Box its in now is 3cu.ft tuned to 32hz
Build log:
post #6 of 45 Old 08-17-14, 09:36 PM
chrapladm's Avatar
Papi
10hz 2nd order will keep it from going over 53mm.
post #7 of 45 Old 08-18-14, 03:59 AM Thread Starter
sub_junkie's Avatar
Dylan
Hmm I'll definitely give a 11-15hz tone an test to see what excursion levels I can reach and if they match in WinISD. Port velocity was kept under 24m/s so I shouldn't have any compression and chuffing happening
Build log:
post #8 of 45 Old 08-18-14, 05:06 AM
chrapladm's Avatar
Papi
I dont worry about extreme excursion levels after porting. I have learned from others that WiniISD is not perfect. It tends to simulate a lossy cabinet for sealed and tends to exaggerate the excursion levels. So being close to 50mm your probably still safe unless your amp truly delivers 2000watts while doing sign waves.
Any videos of them moving?
Love Jacobs videos and cant wait to get my hands on my first pair of Sundown subwoofers.
post #9 of 45 Old 08-18-14, 11:55 AM
GPM
GPM's Avatar
GM
Any specs on this X-15?
Anyway, its construction and even Sundown's description pretty much limits it to a true subwoofer, so not surprised with its performance.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
GPM is offline
post #10 of 45 Old 08-18-14, 08:24 PM
chrapladm's Avatar
Papi
On the same website that has the description are the T/S.
car , decide
