Building a new enclosure for a peerless xls10 with matching passive radiator (400gm) - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 09-13-14, 02:46 PM Thread Starter
New Member
Ken
This is my first time posting, although I've been a long time reader of the forums. I am rebuilding this sub in a new enclosure, with a new amp, since I did such a cheapo job last time I built it. I had basically just thrown it in an old Velodyne enclosure that was made for an 8 inch sub with a passive radiator, and used the amp that was in it (60 W I believe). This was way underpowered and too small and kind of a flimsy enclosure for the sub. I just purchased a 250 W Dayton plate amp, and plan to use a solid slab door that I have for the enclosure. The door is 1.5" mdf with a 1/8" oak veneer on each side. I plan to miter the 4 sides, and have the end walls able to be adjusted in or out to increase or decrease enclosure volume. I'm thinking that with this thickness, I won't need to brace the cabinet internally. Any thoughts? This is my first build from the ground up, and I haven't used any modeling software, just REW. I know the volume target is around 30 liters, and I'm building to be able to go from ~30 to 39 L.
kfraleigh is offline
post #2 of 5 Old 09-13-14, 07:46 PM
HTS Senior Moderator
chrapladm's Avatar
Papi
Re: Building a new enclosure for a peerless xls10 with matching passive radiator (400gm)
SO what will the dimensions be of the enclosure?
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #3 of 5 Old 09-13-14, 08:06 PM Thread Starter
New Member
Ken
chrapladm wrote: View Post
35x11.5x14. The ends will be recessed to get down to the right volume. I plan on recessing one end more than the other and mounting the amp there. That way it has it's own space.
post #4 of 5 Old 09-14-14, 08:57 AM
chrapladm's Avatar
Papi
35H?
Either way just make sure to brace at least every 8" of length in any direction. For the shorter lengths half way should suffice.
Regarding design what are you going to port at? And do you have a pair of PR's?
If you dont have a pair of PR's you will have to keep volume down quite a bit so you dont break your PR. Always best to have a pair of PR one size up than the active driver with similar excursion. I am designing a PR for my own build and excursion goes pretty fast when tuning higher than 25hz. So tune low and have ample amount of Vd for your PR's.
post #5 of 5 Old 09-14-14, 10:01 AM Thread Starter
New Member
Ken
35 inches wide. It will effectively be 30 wide with the recessed ends. 3 internal braces using the same wood should bring volume down to about 30L.
I only have the one PR. Peerless no longer makes these. I'll have to break down and use one of the modeling programs to see how much weight to add.
I'll try to get some pics up Tuesday when I'm off next. I cut the slab door into the 4 mitered pieces so far. I'm curious to see what this thing will weigh when it's done.
400gm , building , enclosure , matching , passive , peerless , radiator , xls10
