-   DIY Subwoofers - General Discussion (https://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/)
-   -   JL Audio 10w6V2 enclosure design (https://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/145521-jl-audio-10w6v2-enclosure-design.html)
warriorcookie 03-14-16 12:49 PM
2 Attachment(s)
I have (4) JL 10w6v2-D4 subs I'd like to use in my setup in 2 separate enclosures.
Room is 14.5' wide, 26' long, and 7.5' tall. Acoustic tiles in ceiling. Corner bass traps going in shortly as well as absorbing panels at first reflection points.
Marantz SR7010 receiver in 7.2.4
(2) QSC RMX1450 for sub amps.
Boston M series towers, center, and surrounds on wall. HSi in ceiling for Atmos.
50% of the time we watch movies, 50% is for 2 channel music.
WinISD recommends a 4.25 cu ft box with a tuning so far below the driver's fs I couldn't get the cone excursion under control with a hp filter.
I've modelled both a 4.25 ft box at 24hz (hp 4th order butterworth @ 21hz) and a 3 ft box at 30hz (hp 4th order butterworth @ 24hz). Cone excursion is at 1000w (500w ea) See attached.
I know this isn't a 15 so it's not ever going to get massive spl at lower freqs.
morca 03-15-16 06:05 AM
Re: JL Audio 10w6V2 enclosure design
You wanna build a closed box or vented?
You think you will not go low.
Butt this are one off the best brands in low extention.
Ik think you will be suprised
warriorcookie 03-15-16 08:06 AM
I'd prefer ported for sure.
MetropolisLake 03-15-16 09:29 AM
morca wrote: (Post 1410873)
It's a 10" driver with 15mm xmax and an fs of 28 hz. Having a dust cap that says JL on it doesn't fix this. It's not going super low.
warriorcookie 03-15-16 09:26 PM
MetropolisLake wrote: (Post 1411025)
Lol, I'm aware. As I pointed out in my first post, I have expectations but I know what a 10" sub is capable of.
warriorcookie 03-15-16 09:36 PM
2 Attachment(s)
I modelled another box based on some vented suggestions.
The red plot is 3cuft tuned to 27Hz. Highpass Butterworth, 4th order @ 23Hz
I also added on a couple parametric EQ's:
-27Hz, Q=6, Gain = 3db
-38Hz, Q=6, Gain = -0.3db
I've never played with parametric EQ's. Is this a bad idea? It extended the low frequencies and controlled the cone excursion.
morca 03-16-16 04:26 AM
You have 4.......
If you think i am wrong,i wont say anything
morca 03-16-16 08:18 AM
27 hz tuning for those sub,s is way to high
I build a 12W3V2 tuned 16 hz, i done this before
4 of these can do much beter .
I read someone thinks i,am wrong.
So be my guest and build them wrong (27 hz tuning)
To bad for these very good sub,s they can do beter.
willis7469 03-16-16 08:04 PM
warriorcookie wrote: (Post 1410985)
+1. Your room is almost 3000cuft. I think ported is the way to go too. And your instincts are correct. Even if you had 50 of those drivers, it wouldn't change the extension. Only the output. If anything you might be able to go down to 25ish(I have not modeled these), but that would probably be it. JL does make some of the best drivers around, but they won't defy physics.
Sent from my iPhone using Tapatalk
warriorcookie 03-16-16 10:17 PM
morca wrote: (Post 1411433)
I don't know how you did it man. I modelled 3cuft at 16 to 20 hz, the cone excursion goes crazy and it looses spl. How's it possible, tuning the box so far below the fs unloads the cone and all hell breaks loose....
