-   DIY Subwoofers - General Discussion (https://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/)
-   -   New Tempest-X2 15" Slot Ported Design (Sketchup Attached) - Feedback Appreciated (https://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/26728-new-tempest-x2-15-slot-ported-design-sketchup-attached-feedback-appreciated.html)
dboff01 03-12-10 05:20 PM
4 Attachment(s)
Hello All,
I'm planning a new 15" slot ported design, probably based around a Tempest-X2 driven by a 500W plate amp or 1000W standalone amp (haven't decided). The subwoofer will double as an end-table and will be replacing an Epik Valor. External dimensions will be 24H x 20W x 28D, 3/4" MDF, slot port 1.5" x 18.5" x 30", tuned @ 20Hz, internal volume approx. 5.3 ft3. These specs seem to be modeling well in WinISD Pro with this driver using an HPF @ 18 Hz.
So I gave Sketchup a whirl last night for the first time. I've attached the file for review. Is the single brace sufficient? Is there enough clearance between the port opening and the underside of the plate amp? I modeled a 3/8" roundover for the port flares, how important is this radius? Any feedback would be welcome.
Thanks,
Steve
Edit 3/14/10: Updated plate amp enclosure drawing and added 2" port height version of enclosure for 1000W standalone amp.
PlateAmp (500W)
5.3 ft3 internal volume
20 Hz tune
1.5"H x 18.5"W x 30"D Slot Port
HPF = 18 Hz
Maximum Port Velocity = 15.25 m/s
ExtAmp (1000W)
5.15 ft3 internal volume
20 Hz tune
2.0"H x 18.5"W x 42"D Slot Port
HPF = 18 Hz
Maximum Port Velocity = 15.85 m/s
lsiberian 03-12-10 06:05 PM
Re: New Tempest-X2 15" Slot Ported Design - Feedback Appreciated
1.5" is way to thin for a slot port. 2.5" at least is suggested. Flaring is only useful for looks.
dboff01 03-12-10 06:22 PM
lsiberian wrote: (Post 245068)
I've targeted keeping the port velocity below 25 m/s based on a recommendation from Kevin (Exodus) in a previous thread. Additionally, Kevin posted a sample down-firing design for this same driver with a 1.5" slot port height. This port with 500W doesn't exceed 16 m/s. Is there some reason I shouldn't follow the advice of the driver manufacturer?
I'd rather not have to increase the port height any due to port length/box volume trade-offs.
gperkins_1973 03-13-10 01:35 AM
Hi there,
Ive just simulated your sub with 750 watts and with the hpf engaged you will only see max 18.5 m/s velocity so you won't have any issues at all that I can see and at 1000 watts you are at 21 m/s.
With a 2.5" port you would need it to be 52" long and with a 2" port you would need to make it 41" long.
You may want to consider doing a 2" port which will go up 14" up the back of the sub which will be fine but there won't really be room for a 52" length port.
A 2" port will bring it down to 16 m/s and thats with a 1000 watts of input power.
I would go the 2" route mate. :T
cheers
Graham
dboff01 03-13-10 07:06 AM
gperkins_1973 wrote: (Post 245143)
Hi there,
cheers
Graham
I think my plan will be if I use the 500W plate amp, I will leave the port as is. If I decide on the 1000W rack mountable amp I will expand it to 2" as I'll have the back wall free for the extra port length.
Thanks for the advice.
Steve
Mike P. 03-13-10 01:05 PM
Re: New Tempest-X2 15" Slot Ported Design (Sketchup Attached) - Feedback Appreciated
Regarding the file you uploaded in your first post, what is a .skp file? I can't open it.
gperkins_1973 03-13-10 01:13 PM
Mike,
Thats a google sketchup file. Downlaod Google sketchup for free. Its the best free program you can get. That's what I used to design my subs. Its absolutely brilliant. Download it, you will see what I mean.
cheers
Graham
Mike P. 03-13-10 08:02 PM
Thanks Graham, I'll give it a shot.
Kevin Haskins 03-13-10 10:24 PM
Plenty of people have built the slot ported design. I've not received one complaint about port noise so I think the 1.5" is sufficient. No harm in going bigger if you want the extra margin of safety but I wouldn't obsess over it if you need to keep it 1.5".
Kevin Haskins
Exodus Audio
gperkins_1973 03-14-10 01:54 AM
3 Attachment(s)
Personally I would still go for a 2" port and chuck 1000 watts at and get another 3db across the board out of it. With a 2" port and double the power the port velocity will be the same as a 1.5" port and 500 watts. Here's some pics to help you mull over it. You really want to get the best out of it in my personal opinion. :T
Cone excursion is still in check too.
I agree with Kevin that the 1.5" will be fine but I don't think you will be doing the driver justice with only 500 watts.
cheers
Graham
