Alternative to BFD, FBQ, DEQ, Anti-Mode, SMS-1 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 28 Old 10-11-08, 11:40 AM Thread Starter
weverb's Avatar
weverb
I have found the Sabine GRQ-3102S. I was able to pick it up off ebay for under $80 shipped. It is an option instead of the BFD, SMS-1, or Anti-Mode....
It is a graphic/parametric equalizer (plus more) that you control by computer. There are no flashing lights or anything distracting. You can still use REW to help develop your filters and then you just plug them in. I will be doing more of a write up once I get to plug it into my set-up. So far I have updated its firmware and been able to do programing no problem. I have attached a picture of the program screen where you can clearly see where you can adjust the delay as well as many other features. All these features actually work all at once. It looks like the only thing this unit does not do are shelving filters. It will do high and low pass filters though. You can go to Sabine's website (www.sabine.com) and look under the discontinued section for the manual and other information. Here is a link to a review of the Graphi-Q line:
http://www.proaudioreview.com/pages/s.0029/t.3279.html
Alternative to BFD, FBQ, DEQ, Anti-Mode, SMS-1-sabine-grq-3102s-screen-shot.jpg
weverb is offline
post #2 of 28 Old 10-11-08, 11:57 AM
Re: Alternative to BFD, FBQ, DEQ, Anti-Mode, SMS-1
Nice find...
Hmmm... reckon Sabine would be interested in helping us develop a new model?
EDIT: Oh well... I doubt it since their cheapest model is around $550 street price. This would definitely only be an alternate solution if you could find it on the cheap like above.
Sonnie is offline
post #3 of 28 Old 10-11-08, 12:04 PM Thread Starter
weverb's Avatar
weverb
Sonnie wrote: View Post
Nice find...
Their tech support was great to talk to. They are located near to where I live. The owner is a UF graduate and has the company located in Gainesville. If there was enough interest they may entertain the thought. Although they do have current models that have the same capabilities, but they have added a crossover option to the units. SO basically now, they are more load with options.
weverb is offline
post #4 of 28 Old 10-11-08, 12:19 PM
You'll have to be sure to investigate how the Sabine defines bandwidth and Q so that the filters REW suggests, actually match. Each equalizer is different, and so REW allows the selection of type in the equalizer pulldown to ensure the filter suggestions are valid.
For example, the DSP1124P, it defines bandwidth between the half gain points as:
Bandwidth (Hz) = centre frequency*(BW/60)*sqrt(2)
With the formula for the relationship between Q and BW being:
Q = 60/[(BW/60)*sqrt(2)]
For the FBQ2496 the bandwidth control adjusts in 1/60 of an octave steps from 1/60 to 5/60 of an octave, and so the formula becomes:
Q = sqrt(2)/BW
and so on..................
SMS
The filter bandwidth in Hz between the half gain points is given by:
Bandwidth = centre frequency/Q
TMREQ
R-DES
Bandwidth = 1.766*centre frequency/Q
Generic
Well, you get the idea anyway........... you'll have to dig in their manual or support docs to find that
brucek is offline
post #5 of 28 Old 10-11-08, 12:25 PM Thread Starter
weverb's Avatar
weverb
Thanks brucek for the information. I picked the "generic" eq in REW and it gave me the correct Q values (section labeled "Width") to plug in.
weverb is offline
post #6 of 28 Old 10-11-08, 05:44 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
brucek wrote: View Post
Yeah, I had that problem with the YDP2006: I'd plug in the recommended filter, then take a sweep and what I got didn't look anything like it was supposed to. IIR, the equalizer appeared to be over-shooting the gain, like a boost or cut would end up being deeper than it was supposed to.
weverb, can you get some better pics of the Sabine? The lighting should be in front of the subject, not behind it.
post #7 of 28 Old 10-11-08, 06:02 PM
Nice find...
weverb has dug up a treasure trove of discontinued pro-audio digital equalizers from companies like XTA, Shure, Sabine and Yamaha that can be had dirt-cheap on eEBay.
weverb wrote: View Post
Does the Sabine have an auto-EQ function like the SMS-1 and Anti-Mode?
post #8 of 28 Old 10-11-08, 07:34 PM Thread Starter
weverb's Avatar
weverb
No, it does not.
weverb is offline
post #9 of 28 Old 10-11-08, 07:35 PM Thread Starter
weverb's Avatar
weverb
Sorry, it was just sitting on the floor with the overhead light on. Will get better pix later.
weverb is offline
post #10 of 28 Old 10-11-08, 08:50 PM Thread Starter
weverb's Avatar
weverb
Here are a couple that Wayne was referring to:
Shure DFR11EQ
http://www.shure.com/ProAudio/Produc...R11EQ5_content
XTA DP200
http://www.xta.uk.com/discontinued.html
Sabine ADF-1200, ADF-2400, ADF-4000, Real-Q2, GRQ-3102, GEQ-3122
www.sabine.com
weverb is offline
alternative , anti-mode , bfd , deq , fbq , sms-1
