What solution do folks use for the dreaded BFD hum? - Page 23 - Home Theater Forum and Systems - HomeTheaterShack.com
post #221 of 330 Old 02-05-10, 01:19 PM
hoofenshnoz
Re: What solution do folks use for the dreaded BFD hum?
has anybody used the Behringer HD400?
hoofenshnoz is offline
post #222 of 330 Old 03-02-10, 05:51 PM
corock's Avatar
corock
I have a terrible ground loop hum in my system. I tried an Art Cleanbox II but it dropped the sub output by several dbs so I made the conclusion that was not a very transparent method and decided to go another route. I thought converting the unbalanced signal from my receiver to balanced was supposed to get rid of it, so i put a Samson S-convert between the receiver and BFD and that made the hum worse. It amplified everything including the hum, not to mention there is always a hum even when my receiver is off because the S-convert is powered. Any thoughts would be appreciated.
corock is offline
post #223 of 330 Old 03-02-10, 06:24 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Lots of remedies discussed and recommend on this thread. Have you tried any of them?
post #224 of 330 Old 03-02-10, 06:39 PM
corock's Avatar
corock
yes, both the art cleanbox and the s-convert.
I can't find where the ground loop is originating from I've tried disconnecting the satellite cable etc. If converting the unbalanced signal to balanced with an S-convert doesn't remedy it should I bother modifying the XLR cable?
corock is offline
post #225 of 330 Old 03-02-10, 06:52 PM
Bruce
I would - completely eliminated my problem
Bruce Fisher is offline
post #226 of 330 Old 03-02-10, 07:03 PM
corock's Avatar
corock
I might as well try it. I'm running rca from the receiver to rca into the Samson, xlr from the samson to xlr into the bfd, trs out of the bfd to xlr into the subs. Which one of these balanced ends should I mod? does it matter?
corock is offline
post #227 of 330 Old 03-02-10, 07:28 PM
The XLR mods are for unbalanced connections, not balanced. Ditch the Samson and modify an RCA to XLR or 1/4" TRS. I'd do both ins and outs, or at least the ins for sure.
post #228 of 330 Old 03-02-10, 07:48 PM
corock's Avatar
corock
the rca to trs cables that phantom cables built me have an unbalanced 1/4 connection so I can't modify the cable into the bfd. Would it be effective to remove the sheild connection from the balanced trs 1/4 out from the bfd?
corock is offline
post #229 of 330 Old 03-02-10, 08:12 PM
Can't hurt to try.
post #230 of 330 Old 03-02-10, 09:27 PM
corock's Avatar
corock
unsoldered the sleeve of the out trs and that didn't help
corock is offline
bfd , dreaded , folks , hum , solution
