What solution do folks use for the dreaded BFD hum? - Page 33 - Home Theater Forum and Systems - HomeTheaterShack.com
post #321 of 324 Old 04-23-16, 07:55 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: What solution do folks use for the dreaded BFD hum?
Bob was referring to leaving no connection for Pin 1, like you have already done.
What are you using for the BFD’s output? I’d suggest a XLR/RCA cable like you have for the input. Don’t know if it’ll make a difference, but it can’t hurt.
Failing that, I’d suggest getting back to the basics: Disconnect all source components from the system, and then re-connect them one at a time. Typically the offending piece is a cable box or satellite receiver.
post #322 of 324 Old 04-23-16, 08:45 PM
Ron
I have no doubt that it is the BFD. My AVR is a Denon with unbalanced sub output to the BFD. I just tried an XLR to RCA like you suggested from BFD to subwoofer. Same hum. I happened to have one because I had gone to Guitar Center last week and bought a Direct Box PDI passive ground lifter. (I had to use the XLR in order to connect it to the BFD). I put it between the Denon and BFD and the hum disappeared. But it cut the output from the Denon to the BFD (hence the subwoofer) so much that I thought the connectors weren't working. It was only after I increased my output from the receiver to the BFD (subwoofer) from -1.5 to +8.5 that I heard the sub again. I was afraid it was mucking up my BFD filters I have set so I took it out and I plan on taking it back. I was thinking of trying the Hum X but guitar center didn't have one on hand and the girl suggested the direct box. Should I just go the hum x route and see if that works? Like I said it is not my cable or anything else causing the hum. It is solely the BFD. If I take the BFD out and go straight to the subwoofer there is no hum whatsoever on anything anywhere anytime. But I really like what the BFD does for the sound of my system and want to keep it going. I do appreciate your time.
Thanks again,
Ron
RonS1958 is offline
post #323 of 324 Old 04-24-16, 05:03 AM
Ron
Wayne,
Well back to the basics didn't take long. I just unhooked my cable feed to the DVR and the hum went away. (I had just the BFD and subwoofer on.)
Went outside and looked into the box and the ground cable was not connected at the grounding block. Cable guy just did some work a couple of weeks ago. But after I hooked it back up the hum is still there just a whole lot less but still noticeable. I will read into the solutions for the cable feed.
Thanks,
Ron
RonS1958 is offline
post #324 of 324 Old 04-27-16, 06:44 PM
Ron
I ordered the Jensen ISO-MAX VRD-1FF cable Isolator from cable Solutions on EBay on Sunday, got it today, hooked it up and pleased to say that the hum is gone. No discernible difference in sound at all.
I never understood that the root of the hum was because of the way that cable must be grounded. (I did test the cable ground and it was proper). I had always thought the problem was because of the AVR to BFD connections. I sure did learn a lot. Thank you so much for your help and getting me pointed in the right direction Wayne.
Ron
RonS1958 is offline
bfd , dreaded , folks , hum , solution
