Revised Firmware V1.4 for the DSP1124P with V1.3 ONLY! - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 138 Old 01-22-07, 07:42 PM Thread Starter
Re: Revised Firmware V1.4 for the DSP1124P
Just use a drill and if necessary a hammer... leave it plugged up for an extra surge to burst it loose...
Sonnie is offline
post #52 of 138 Old 01-22-07, 08:51 PM
jagman
Is the firmware necessary if you don't use the midi jacks?
jagman is offline
post #53 of 138 Old 01-22-07, 09:04 PM
No...........
brucek is offline
post #54 of 138 Old 01-23-07, 02:48 PM
lovingdvd
I was planning to pick up an 1124P from a local retailer. Am I definitely going to hit this bug with the midi (wanting to use REW to send filters/EQ to it), or does the issue only affect some units? Seems like this issue recently came up, so what changed that broke this (seems like many people in the past did not have this issue?)?
lovingdvd is offline
post #55 of 138 Old 01-24-07, 04:25 PM
Can you update the title of this thread to say "revised Firmware v1.4 for V1.3 DSP1124P".
I'm new here, but if I read the threads correctly the V1.0-v1.2 DSP1124P BFDs don't have a problem between the Midi interface and REW do they? I have an older BFD and was thinking "oh " I need to upgrade the thing if I want to use a midi interface to store the filter values...
thanks
Dan
Lucky7! is offline
post #56 of 138 Old 01-24-07, 05:04 PM Thread Starter
Re: Revised Firmware V1.4 for the DSP1124P with V1.3 ONLY!
Hi Dan and welcome to the Shack!
Good idea... and done!
Sonnie is offline
post #57 of 138 Old 01-30-07, 01:44 PM
lovingdvd
I got my 1.4 chip but not in a hurry to install it. I've gotten used to manually entering the data into the BFD and figure I might as well save the $40 on the MIDI cable... still undecided though.
BTW, after I replace the chip will I need to reprogram all my filters in the BFD? Or is that stored in a different chip in the BFD?
post #58 of 138 Old 01-31-07, 06:27 PM
One thing I found that eases the replacement is to remove the pin cable to the right. Just pop up the glue, remove the pin connector and then you have a "whole heaping passle" of room. I also use a hot glue gun to put a dab of glue on both connections.
Lucky7! is offline
post #59 of 138 Old 02-12-07, 05:06 AM
New Member
akardash
Hi All!
First of all I would like to thank everyone on this forum for the effort you, guys made to solve this DSP1124P 1.3 MIDI problem!
Finally, I've received new eprom with 1.4 firmware (thanks Steph from www.Hobbyroms.com) and swapped out the ver 1.3 chip.
(I'm in Australia and it worked out very well for me, it took 10 days for the parcel to arrive)
Now I'm very happy to have my 1124 unit fully functional.
Andriy.
akardash is offline
post #60 of 138 Old 02-12-07, 12:59 PM
Joe
OK, I tried to start a separate thread since it really is a different issue BUT did not get a definitive answer.
My question is: What is the difference from V1.0 to 1.1 to 1.2 to 1.3?
The difference from 1.3 to 1.4 is well documented here - I'll go out on a limb and say the only difference is that MIDI is enabled right???
But, I really would like to know of the differences from the other versions. Anyone?
TIA
blownrx7 is offline
dsp1124p , firmware , revised , v13 , v14
