Revised Firmware V1.4 for the DSP1124P with V1.3 ONLY! - Page 9 - Home Theater Forum and Systems - HomeTheaterShack.com
post #81 of 138 Old 04-19-07, 12:34 PM
Joe
Re: Revised Firmware V1.4 for the DSP1124P with V1.3 ONLY!
My impression is that 1.0, 1.1, 1.2 should work just fine without mod, and 1.3 needs the mod. Is this a correct assumption?
Shawn,
Your assumption is correct. I asked what the differences were from 1.0 to 1.1 and 1.2 and no one really knew (of course I should have asked Behringer). No one noticed a difference either at any rate.
I'm betting that any changes affected the original target audience (PA system guys who needed to kill feedback issues)
That being said, it seems the chances of finding anything but 1.3 in the stores is pretty low. YOu'd have to find a place that did not move a lot of stock to find the older versions.
blownrx7 is offline
post #82 of 138 Old 04-19-07, 03:23 PM
slidell
Shawn, if you absolutely need the filters working via midi then do as others suggest and contact Behringer. Other than midi, my 1.3 chipped 124 works just fine.
slidell is offline
post #83 of 138 Old 04-19-07, 09:48 PM
arrived in the mail today. took 5 mins to open up, scrape the glue off and put the chip in before.
if you haven't done this before, make sure you look for the notch on the eprom so you orient it the right way, and make sure you straighten up the pins so it lines up in the sockets.
I really appreciate the terrific customer service from behringer. wish all companies had service like that.
Lucky7! is offline
post #84 of 138 Old 04-28-07, 07:04 PM
Wow...I just saw this thread. I have a 1124p that I have had for a bit but never got around to setting it up. I started to play with it this weekend and found this thread. I aways planned on using the midi support so I quickly checked my version after reading through all the comments.
It turns out mine is version 1.0. The production date of the unit seems to be Feb '05. I was hoping for version 1.2 just so I wouldn't have to go the extra steps. However, now I wonder if sticking with version 1.0 is just as bad. It may have the midi support bur what else might they have fixed from 1.0 to 1.4.
Lucky7! is offline
post #85 of 138 Old 06-07-07, 05:44 PM
slidell wrote: View Post
Same here. Just got e-mail yesterday saying the 1.4 chip is in the mail
I posted mine on Sunday evening (6/4/07), four days later and still no reply. I'll wait another day before I ping them gently for a response.
Lucky7! is offline
post #86 of 138 Old 07-04-07, 07:26 AM
Sparks
I requested my revised Eprom a little over 3 weeks ago from Behringer Tech Support. Behringer Customer Service was very prompt to reply but it appears the Eprom will not be available for 6-8 weeks. It would appear they were not ready for the rush of requests on this issue. They did refer me to a place where I could "buy" the Eprom. They apparently were serious.
Making a customer wait 6-8 weeks for correction of a quality issue as simple as an Eprom is not good....
Anyone else having this problem or have you been able to get the Eprom via some other way?
Testpattern is offline
post #87 of 138 Old 07-11-07, 07:22 PM
...and they're in stock again. woot.
Response (Chris P.)
11/07/2007 11.24 AM
Dear Ward,
We finally received the V1.4 EPROMS for the DSP1124P. We will mail it to the following address.
Lucky7! is offline
post #88 of 138 Old 07-12-07, 08:13 AM
Sparks
I've been working with Behringer for over three weeks concerning them supplying a corrected Eprom. They're telling me 6-8 weeks. Or I could go to someone and pay them to burn an Eprom....
What a bunch of .... it's their problem but they appear really laid back about doing anything about it.
post #89 of 138 Old 07-22-07, 07:30 AM
I am ver. 1.0 should I leave it alone or upgrade ?
I am just getting into this so have a major learning curve ...
Just wondering if I need to upgrade to 1.4 I will be using midi when I get that figured out. My take on this thread is I am OK as is ..... that only if I went or had 1.3 I would need the upgrade.
I will be going with a 2496 some day though as I only need the two presets
I will use a house curve and a flat one and use bypass
Lucky7! is offline
post #90 of 138 Old 07-22-07, 07:39 AM
Leave it... version 1.0 is fine..
brucek is offline
dsp1124p , firmware , revised , v13 , v14
