FBQ2496 - a few initial setup questions - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 12 Old 08-30-10, 02:25 PM Thread Starter
My FBQ2496 is expected to arrive tomorrow YAY Have been reading the FBQ2496 manual (which was a bit "thin" I think) + the BFD guide here at the shack. I plan on programming it via MIDI. My questions are mostly about initial setup of the FBQ2496 prior to programming the first filters.
Question 1: The BFD manual says to first setup the correct input level in bypass mode by pressing IN/OUT button, the FBQ2496 manual says to press 'bypass' to enter "hard bypass", this is the same thing right?
Question 2: Do I make my "baseline" frequency response measurement in 'bypass'-mode or do I need to enter some "PEQ with 0 filters active"-mode?
Question 3: More or less a followup on q2, do I need to do any other adjustments/settings on the FBQ2496 prior to programming the filters via REW (besides the MIDI settings)?
Question 4: No need to clear filters before programming new ones right? Old filters get overwritten when writing new ones?
Sorry if my questions have been answered before.
NixPix is offline
post #2 of 12 Old 08-31-10, 10:33 AM
REW Author
JohnM's Avatar
John
Re: FBQ2496 - a few initial setup questions
NixPix wrote: View Post
Right
Either is OK
No, and on the FBQ Midi should be enabled by default.
Yes, REW overwrites all the filters each time
JohnM is online now
post #3 of 12 Old 08-31-10, 12:24 PM Thread Starter
Thank you John. I was to slow, I meant to edit my post and remove the questions cuz I figured it all out Sorry for wasting your time a bit.
Recived my unit today - hooked it up and programmed my first filters, and I have to say - I love the FBQ!
Now I'm gonna tweak tweak and tweak ... what would you say is prefered if I find the bass a tad 'tame' (need a bit more ooomph/kick), try a steeper house curve or simply turn up the volume of the subwoofer? Also, any other tips to improve things are very much welcomed!
Here's the initial measurements:
Baseline with fronts
Corrected with filters (with fronts)
NixPix is offline
post #4 of 12 Old 08-31-10, 03:22 PM
REW Author
JohnM's Avatar
John
The correction looks to have worked well. It is worth taking some time to get used to the equalised response, and to take a wider look to see how the sub is integrating with the fronts.
JohnM is online now
post #5 of 12 Old 08-31-10, 05:26 PM Thread Starter
I'm not 100% sure of what to look for when integrating the sub with the mains. An as smooth transition as possible at the crossover frequency? What else? Do I accomplish this solemnly with the phase/distance to sub relative to the mains?
NixPix is offline
post #6 of 12 Old 09-01-10, 03:18 AM
REW Author
JohnM's Avatar
John
Mainly looking to avoid sharp dips or peaks in the crossover region, the sub's phase or receiver's distance settings are your main tools, yes. Also want to see how the overall level of the sub compares with the mains.
JohnM is online now
post #7 of 12 Old 09-02-10, 06:50 PM
My FBQ2496 come with MIDI disable. My firmware is ver 1.1. What's your firmware version? You can see the firmware version when you powering up the unit before showing RUN.
pierreye is offline
post #8 of 12 Old 09-03-10, 09:58 AM Thread Starter
pierreye wrote: View Post
Mine came shipped with firmware 1.0. Any idea whats been corrected or changed between 1.0-1.1?
NixPix is offline
post #9 of 12 Old 09-04-10, 05:35 AM
I had no idea on the difference but if you had the midi cable, you can request the firmware from behringer to upgrade.
Posted via Mobile Device
pierreye is offline
post #10 of 12 Old 09-04-10, 07:21 AM
blacksound's Avatar
sound crazy
Sir,
recently i have purchase my BFD 2496.
Do i need external audio card or configure this with my PC inbuilt sound card.
Please give me suggestion for m-audio mobile use external
blacksound is offline
fbq2496 , initial , questions , setup
