MiniDSP HOWTO - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #21 of 46 Old 05-12-13, 10:20 PM
im thinking of buying one for my sub im building. do you have to buy the software or does it come with it? and also was shipping expensive i see on their website they come from china
mccolgan4731 is offline
post #22 of 46 Old 05-13-13, 08:36 AM
SGA
mccolgan4731 wrote: View Post
You have to buy a plug-in. Otherwise you can't do anything with the miniDSP.
Shipping was cheap. 10 bucks or so.
sga2
sga2 is offline
post #23 of 46 Old 05-13-13, 11:13 AM
Alright good to know. And what is the difference between the "kit" version and the "in the box" version? the kit is $99 and the in the box is $125 is the only difference the fancy box/shell it comes in. what am i losing if i bought the kit version? and what "Rev" is the kit version. the box version come in RevA (<.9v rms) or RevB (2v rms) i need RevB. Do you just program the kit version to what Rev you need?
post #24 of 46 Old 05-13-13, 11:55 AM
SGA
Kit is the guts only, no enclosure. Enclosure gives some protection against dust and makes it easier to pick up and move around (without fear of touching internals. AFAIK all units are configurable via jumper between Rev A and Rev B.
sga2
sga2 is offline
post #25 of 46 Old 05-13-13, 10:42 PM
Alright awsome thank you for all the info ill be getting one. and also what does AFAIK mean
post #26 of 46 Old 05-16-13, 05:36 AM
SGA
As Far As I Know.
sga2
sga2 is offline
post #27 of 46 Old 07-07-13, 07:33 PM
Re: MiniDSP HOWTO
Hello, I just stripped a length of RCA for my input to my 2 x 4 balanced DSP. Which end goes to the positive and which goes to the negative? Thanks guys.
ClevelandFreeman is offline
post #28 of 46 Old 07-10-13, 11:50 PM Thread Starter
Myles
Re: MiniDSP HOWTO
Sorry for the delay. As I'm sure you've figured out by now, it doesn't matter. But just for minor sanity purposes, I'd connect the shield to the - terminal and the center pin to +.
<-- SOLD!
Wooderson is offline
post #29 of 46 Old 09-03-13, 09:18 PM
Re: MiniDSP HOWTO
I've been debating buying one of these for a while. But I'm still not sure what to get (even after reading this thread). I am using a Pioneer reciever and a Dayton plate amplifier. So I assume I need the unbalanced unit. I'm also assuming the 2.1 plugin is the most suited for subwoofer duties (would be nice if mi i dsp made a true subwoofer plugin). Because I'm using one sub only, can I also assume that I use input 1 and output 1 only?
Finally, what is the difference between rev1 and rev2?
Thanks
f0zz is offline
post #30 of 46 Old 02-04-14, 06:51 AM
Waffles
Re: MiniDSP HOWTO
Wooderson wrote: View Post
I am a bit confused by the labeling for the MiniDSP Output XLR side. Shouldn't S be connected to Shield?
(This is for using XLR also as input.)
waffles is offline
howto , minidsp
