Review: Yamaha YDP2006 Digital Parametric Equalizer - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 26 Old 07-09-14, 06:42 PM
tonyvdb's Avatar
Tony
Re: Review: Yamaha YDP2006 Digital Parametric Equalizer
Is the problem caused by a dirty pot or is it more than that Wayne?
Home theater:
Living room system:
tonyvdb is offline
post #22 of 26 Old 07-10-14, 11:09 AM
New Member
I do not doubt it would cost more than I would want it to BUT they are not coming up that often for sale!
Just got the second one and I think it is working correctly.
For a moment it was acting a little funny but now all seems to be fine.
wademcinnis is offline
post #23 of 26 Old 07-10-14, 05:27 PM Thread Starter
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Can’t say I’ve ever come across the problem the OP is describing, Tony - assuming it is indeed the YDP (we’ll know for sure once he hooks up his “new” one). Doesn’t sound like any problem with a pot that I’ve ever had. The only actual potentiometer the YDP has is the input knob anyway.
post #24 of 26 Old 07-11-14, 11:36 AM Thread Starter
Wade, upon further thought I think I have an idea of what could be the problem with your original issue, with the low frequency noise. It’s probably a dirty back-panel level switch, most likely the output switch. Anytime I’ve had weird output level issues, this has always been the problem (a recurring one for me, since I run a fan to keep them cool). Try taking the top panel off and squirting some tuner cleaner into the switches and working them back and forth a few times. I’ll be surprised if this doesn’t fix the problem.
post #25 of 26 Old 03-23-19, 02:55 PM
New Member
Wayne,
Thanks for the review. Based on your review, I bought one of ebay for use in a 2.0 system for the low end frequencies.
I have rca to xlr cables and have a hum in the speakers. It's not overpowering, but I notice it.
You suggested snipping the connection between pin 1 and pin 3. In my xlr, pin 3 is connected to pin 1, and then pin 1 is connected to ground. Should I snip both connections from pin 1 or do I need to re-solder pin 3 to ground and then snip both pin 1 connections?
blaszkma is offline
post #26 of 26 Old 03-23-19, 06:31 PM Thread Starter
Can’t say I’ve ever seen an XLR with a connection to the ground, but I’d certainly suggest cutting it. If that doesn’t work, then try disconnecting Pin 3 from Pin 1.
digital , equalizer , parametric , review , yamaha , ydp2006
