-   Electronic Processing/Equalization Devices (https://www.hometheatershack.com/forums/electronic-processing-equalization-devices/)
-   -   amps eq up the wazoo (https://www.hometheatershack.com/forums/electronic-processing-equalization-devices/169377-amps-eq-up-wazoo.html)
dreadknot 06-09-17 12:16 PM
i need some advice
i have a 3 Crown XLI800 to drive 2 BIC
Acoustech PL-28II Center SpeakerS ,2
BIC Amercia Acoustech Platinum Series
PL-89 tower speakers ,and 2 BIC America
Venturi DV84 2-Way Tower Speakers at
200watt do i need ART CLEANBoxPro 2
would that help i have Rockville REQ231
Dual Band graphic Equalizer connected
inbetween the each amp from a onkyo 717
useing rca to xlr cables from the recevier from to the Equalizers an to the amps xlr to xlr
an my audio singnal is low i have to set the onkyo 717 output per channel at 10+db an the volume at 55 an the amps volume at 70 to pound. id like to set them 50 an the 717 at 45 an not have the sound turn into a whisper but be load an clear
anyone have advice
Wayne A. Pflughaupt 06-10-17 07:57 PM
Re: amps eq up the wazoo
We have no reference for your Onkyo volume settings, especially since the Crown has no numeric indicators. What is the scale range (i.e. from 0 to 100, or something like that)?
Do you hit “pound” at a higher setting on the Onkyo using the EQ and amp, compared to not having them?
