-   Forum Help | Suggestions (https://www.hometheatershack.com/forums/forum-help-suggestions/)
-   -   Forum Use Tips Thread (https://www.hometheatershack.com/forums/forum-help-suggestions/21281-forum-use-tips-thread.html)
Sonnie 09-14-09 07:59 AM
This thread is for tips that make use of the forum easier.
Feel free to post tips you find help you in using the forum.
Sonnie 09-14-09 08:03 AM
Re: Forum Use Tips Thread
I find that I use the New Posts link probably more than anything else. It gives me a quick and easy way to see all the new posts since the last time I visited the forum. I can scroll down through the list, check out the threads I am most interested in or that need my attention, then use my back button or simply click the New Posts link again to go back to the list. Once I am done I click Mark Forums Read and it clears out all posts.
http://www.hometheatershack.com/imag...s_markread.gif
engtaz 07-10-10 03:09 PM
How do you stop being subscribed to threads you reply to?
Sonnie 07-10-10 06:16 PM
Change the Default Thread Subscription Mode in your UserCP Edit Options... :T
HDJeff 09-25-12 08:53 AM
I accidentally made 2 threads of the same thing, how do i delete one.
Thanks
Mike P. 09-25-12 09:04 AM
Members can't delete threads, Admin will look after it.
alatham 01-25-14 01:37 PM
How do I setup a "My System" drop down from my profile so others can select that from my posts?
Tonto 01-25-14 03:59 PM
In the top menu, click on UserCP. You will get a drop down, one of which will be "My Profile." Click on that & it will populate your profile, one of which is where you can put your equipment in.
alatham 01-25-14 04:13 PM
I put my system info in but it does not appear as an option to view.
Sonnie 01-25-14 08:17 PM
Make sure you have it turned on...
http://img809.imageshack.us/img809/1508/r99w.png
