Painted Wall versus Actual Screen - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 19 Old 11-03-15, 10:35 AM Thread Starter
Jeremy
Hi All,
I am new to this hobby...I use to be really into flying 3d RC airplanes, but just recently sold everything RC related to invest in a home theater (after seeing my planes sit in the garage collecting dust for over a year because I never have time to fly, I figured it was time to let them go...it was hard, I almost cried, but I cut the cord and said good bye to that chapter of my life). I am quickly realizing this could easily be my next addiction, that is, trying to get the perfect home theater experience. Anyway, what I am trying to decide now is whether to spend my limited funds on a projection screen or just project onto a white wall. When I first started down this road, I thought it was a no brainier, I should get an actual screen. However, now that I have my projector and I am seeing the quality of the picture on my plain white wall painted with white Kilz2, I actually do not see how the picture quality could improve much because it already looks so good.
My viewing environment is 100% light controlled (it will be mostly completely dark when viewing). I am using the BenQ HT1075 as my projector.
In researching the question, a few reasons I have seen others cite for why not to just project onto a white wall is 1. you will see the texture of the wall, 2. the wall is uneven, 3. it does not reflect the picture back to your eyes quite as well as actual profession grade screen material does. If just for reasons 1 & 2, (texture and uneven), I would not be convinced to spend money on a screen. I personally do not see the texture in my wall when viewing the projected image from any more than a few feet back, although I will still apply some plaster to make it as flat as I can just because it's cheap and I can. And as far as any unevenness, maybe I am just lucky, but my wall seems flat to me, every point in the picture seems in focus when I look at it.
The reason I am not sure about is #3, the quality of the picture, contrast, color brightness, overall picture quality...of actual (insert your favorite screen material here) type screen material versus simply projecting onto a blank white wall. My dilemma is two fold, time constraints and budget constraints...meaning, I work a lot so I do not have unlimited time to futz around with countless experiments of different kinds of screens and secondly, even if I did have the time, I do not have the money to do so, I cannot spend even $300 just to see if I like it better. Right now I am projecting onto my white wall that has been painted with Kilz2 and it looks great. To be honest, I do not really see how the picture quality could get much better, I mean, maybe it could improve marginally, but unless I am really missing something here, I cannot for the life of me imagine how a screen would be drastically different because the picture is already crystal clear and the colors look right to me, black level is fine and the screen is plenty bright... what is there to improve upon?
So basically, I want to take a survey. I am looking for help from anyone that has personally seen a projector projected onto a white wall as well as that same projector projected on your favorite screen material. If you could let me know on a scale from say, 1%-100% how projecting on a white wall compares to projecting on screen material. 100% being perfect, cannot get any better picture, and 1% being, well, basically no picture at all.
My guess, without having seen anything accept the white wall, is white wall is about 94% and the perfect best screen material possible would probably be about 96%-97% (given my projector would be the weak link keeping it from 100% accurate picture). If I am right, then in my opinion, my money would be better spend upgrading some other component of my home theater versus getting a screen for the marginal 2%-3% increase in picture quality that would hardly even be perceptible except to the most discerning eye. On the other hand, if I am just totally not getting the picture (pun intended) and the variance is more like a 20% improvement in actual screen over white wall, I would most likely want to spend the money on a screen. Secondly, if you think an actual screen is significantly better, which screen material are you using?
Thanks,
Jeremy
jocanon is offline
post #2 of 19 Old 11-03-15, 11:11 AM
tonyvdb's Avatar
Tony
Re: Painted Wall versus Actual Screen
The simple answer is a screen will be better than a white painted wall however there are paint options that do work quite well but need some mixing to achieve the right results.
Jamestown screens are relatively inexpensive but he can test you patience in his delivery times. I have one of his fixed screens for a few years now and can not complain and it was an improvement over the painted wall I originally used.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 19 Old 11-03-15, 11:19 AM Thread Starter
Jeremy
tonyvdb wrote: View Post
Thanks tonyvdb for your reply. I do not doubt it would be an improvement, but I am wondering how much of an improvement. I mean, was it like night and day, or how closely did you have to look to see that it was an improvement. I know this is a very subjective question, that is why I am attempting to put a number on it. One person could say, "It was a huge improvement!" While another might say, "It was only slightly better." While it may be possible both are really saying the same thing in essence because it's possible in the first guy's opinion a 2%-3% increase in picture quality IS a huge improvement, while to the second guy a 2%-3% increase in PQ is only a slight improvement. Does that make sense?
I know it is not an exact science, but could you just throw some numbers up there to give me a sense of what you are seeing from your perspective, a 2%-3% increase in quality, 20%-30% increase, 10%-15%...etc.
jocanon is offline
post #4 of 19 Old 11-03-15, 11:51 AM
Talley's Avatar
4 months for my delivery but I agree.
To answer the original posters questions
Jamestown screen if it equals 100%
white painted grey wall using kilz 123 - 75%
I saw a considerable improvement but the white wall was pretty impressive for what it was ($12 in paint) Most of my improvement went from going from a textured wall to a smooth screen though.
Master Electrician
XPA-7 & Krell Showcase 7 | XMC-1 | SVS Ultra Tower system | HSU VTF-15H MK2 | BenQ W1070 | Jamestown 135"
Talley is offline
post #5 of 19 Old 11-03-15, 12:57 PM
tonyvdb's Avatar
Tony
It was a good 35% improvement over the painted wall.
Home theater:
Living room system:
tonyvdb is offline
post #6 of 19 Old 11-03-15, 01:22 PM Thread Starter
Jeremy
Wow, really, you saw that much improvement? I am looking at the 150" Jamestown screen for only $325. If it really provides the improvement in PQ you guys say it does (25%-35%), I think that is worth it.
My only reservation is that Talley said the improvement was mostly from going to textured surface to smooth. What if I cannot see the texture? Is it possible that I am seeing it, but not knowing I am seeing it? For instance, if I were to see the projected image on a screen and the textured wall back to back, then I wonder if I would see a difference? Right now, even if I strain, I cannot make out any texture whatsoever, maybe your eye site is better than mine, seriously. I wish there was a way to test it out without forking over the cash...I got a sample from somebody, but it is about 4" by 3", pretty much useless to use as a PQ test.
jocanon is offline
post #7 of 19 Old 11-03-15, 01:28 PM
tonyvdb's Avatar
Tony
Are you the only one watching movies in this space or are the lots of seating position's? Direct viewing with a painted wall is going to be fairly close but anyone sitting off to the sides will suffer alot of image quality loss.
Home theater:
Living room system:
tonyvdb is offline
post #8 of 19 Old 11-03-15, 01:34 PM Thread Starter
Jeremy
Good to know, I will check that out. I have only ever watched it head on. Eventually there will be multiple seating. The room dimensions are 20' x 20' x 8' ceiling.
jocanon is offline
post #9 of 19 Old 11-03-15, 01:46 PM Thread Starter
Jeremy
What if I use plaster to smooth out the texture?
jocanon is offline
post #10 of 19 Old 11-03-15, 02:17 PM
Talley's Avatar
You know your probably closer to the right number than me. I was originally thinking 30% but ya I'd almost agree. Somewhere between 35-25% improvement. It's pretty significant.
To the OP:
You cannot see the texture... or at least I could not but this is sitting head on too. The texture just gave a grainy look which actually mimic'd film... I thought it was pretty cool. I did notice that sitting off to the sides it was very noticable.
So directly in front of the screen.... probably a 25% improvement.... off to the side closer to 60% improvement. I remember now checking angles but I don't care about any place but my seat so thats what I was referencing.
Master Electrician
Talley is offline
actual , painted , screen , versus , wall
