-   General Screen Discussion (https://www.hometheatershack.com/forums/general-screen-discussion/)
-   -   Tension or manual (https://www.hometheatershack.com/forums/general-screen-discussion/111882-tension-manual.html)
moto111 02-14-15 06:37 PM
Tension or manual
So i have a 14x18 room seating is about 12-15 feet range light controlled painted black. I have a benq1070 and am looking to buy a screen. Been looking at 135 or 150inch dont know which yet. But its going to be a elite screen ethier the starling tension which is about 900 bucks or a manaual which is about 300. Thoughts i mean i can leave the screen down most of time if i wanted. just debating if the extra 600 bucks will result in a better picture?
ellisr63 02-14-15 08:28 PM
Re: Tension or manual
moto111 wrote: (Post 1094930)
Have you thought about a fixed screen?
moto111 02-14-15 08:57 PM
Theres a foundation wall with a ledge sticking out and i dont want to deal with building anything plus my tv may go behind it in the future. Debating just buying a manual screen 150 and leaving it down for 3-400 bucks. 950 bucks for a tensioned screen is alot more then my pj cost
ellisr63 02-14-15 11:47 PM
moto111 wrote: (Post 1095018)
The reason for the tension is to prevent curling the side edges... If that is ok with you then just get the cheaper one.
moto111 02-15-15 12:17 AM
I've also been reading and they say that the big screens over 120 get the waves faster . In two years il probably be replacing pj and screen to a fixed one after i decide to build something . Will a electric or manual normal screen get me 1-2 years at least before being terrible
Yiannis1970 02-15-15 01:56 PM
It's true. The bigger they are, more easier to get waves.
afterlife2 08-19-15 11:21 AM
ellisr63 wrote: (Post 1095002)
What is the cheapest/good fixed screen? I'm thinking 110. I have 100 inch that is getting some waves.
ellisr63 08-19-15 01:17 PM
afterlife2 wrote: (Post 1277306)
DIY is the cheapest. SeymourAV sells the material if you want to make your own and have an excellent screen. I am using their 180 scope screen DIY. With the screen cut, and grommets installed it was under $500...all I had to do was make the screen frame which was very easy.
afterlife2 08-21-15 10:38 AM
ellisr63 wrote: (Post 1277394)
Hi Ellis budget wise I meant $100-150 maybe?
ellisr63 08-21-15 11:19 AM
afterlife2 wrote: (Post 1278898)
The 110" diagonal XD screen material would be around $200. If you look around you might be able to find some Draper screen material for $50-$100. I found some Draper or Dalite for $50 (end of roll) a while back, so I am sure yoou can find some if you are patient.
