-   HDTV | Video Displays | Processors (https://www.hometheatershack.com/forums/hdtv-video-displays-processors/)
-   -   Sony KDL picture settings help (https://www.hometheatershack.com/forums/hdtv-video-displays-processors/65528-sony-kdl-picture-settings-help.html)
nicexshot 02-11-13 10:36 PM
I just purchase a Sony KDL 55hx750 and I want it to know what are some nice picture settings that I could try ?
mechman 02-12-13 08:29 AM
Re: Sony KDL picture settings help
I would recommend purchasing one of the various calibration discs and following the guide for setting up your display. :T
JBrax 02-12-13 11:51 AM
221 Attachment(s)
I own the Sony 55" KDL-55HX800 and had a ISF certified tech come in and calibrate it. To be honest I prefer the standard setting that is already preset in the display. Vivid or torch mode as some call it was just too much and the calibrated version was just a tad too dull for me.
JimShaw 02-12-13 01:19 PM
As anyone tried this for a tune up?
For $1.99 app on your smart phone or iPad, this might help
http://www.hometheatershack.com/gall...le.php?n=10786
Jungle Jack 02-12-13 03:36 PM
Hello,
Here is a good baseline set of adjustments.
--Picture Adjustments menu--
Setting Memory: [any]
Picture Mode: Custom
Backlight: 1
Picture: Max
Brightness: 50
Color: 52
Hue: G1
Color Temperature: Warm 2
Sharpness: 40
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot Noise Reduction: Off
Motionflow: Off
CineMotion: Auto 1
--Advanced Settings menu--
Black Corrector: Off
Adv. Contrast Enhancer: Off
Gamma: +1
Auto Light Limiter: Off
Clear White: Off
Live Color: Off
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturalizer: Off [grayed out]
i/p Conversion Preference: Quality [grayed out]
--White Balance menu--
R-Gain: -2
G-Gain: 0
B-Gain: -1
R-Bias: -2
G-Bias: -2
B-Bias: -2
--Screen menu--
Wide Mode: Full
Auto Wide: Off
4:3 Default: Off [grayed out]
Auto Display Area: Off
Display Area: Full Pixel
Screen Position: [grayed out]
Vertical Size: 0 [grayed out]
--Pro Picture Setup menu--
[all settings default/Auto]
--Home Menu>Settings>Preferences--
--Scene Select menu--
Cinema
--Eco menu--
Power Saving: Off
Light Sensor: Off
mechman 02-13-13 11:41 AM
JimShaw wrote: (Post 590294)
Ahem... :foottap:
