Bass Trap Test... did this fail? - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #1 of 15 Old 05-06-16, 07:56 PM Thread Starter
Blacklightning's Avatar
Unhappy Bass Trap Test... did this fail?
I heard a while ago about buying insulation and leaving it in the bag to test in out.
The cheapest, easy to find rigid fiberglass in my area is Roxul R6 ComfrotBoard IS.
I got 5 boxes of the stuff and did some tests.
Did this fail as a test or is this stuff too rigid.
Boxes have 6 panel at 1.5 Inches so 48' x 24' x 9'
First SPL graph Blue is before Yellow is after.
Decay graph first before second after... same with Waterfall graph.
Blacklightning is offline
post #2 of 15 Old 05-06-16, 08:03 PM
ellisr63's Avatar
Ron
Re: Bass Trap Test... did this fail?
Do you have before and after tests... I am assuming the ones you posted are after. Or is this before and after?
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #3 of 15 Old 05-06-16, 09:56 PM Thread Starter
ellisr63 wrote: View Post
I will add labels, but yes they are before and after.
post #4 of 15 Old 05-07-16, 09:10 AM
Medi0gre's Avatar
Labels...
Bueller/ Lightning...
klaatu barada nik*cough*
Medi0gre is offline
post #5 of 15 Old 05-07-16, 03:14 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
The “after” graphs shows overall less ringing between 60-190 Hz. Whether or not it’s enough to make an audible difference, you’ll have to be the judge of that.
post #6 of 15 Old 05-08-16, 12:43 AM
Juan Josť
You have to remove the plastic and put a cloth miss the air so that the traps are more or less effective.
You can line them wadding and then an acoustic fabric to your personal taste.
I apologize for my English,translator use.
Greetings.
hemiutut is offline
post #7 of 15 Old 05-08-16, 12:13 PM
bpape's Avatar
Bryan Pape
The frequency response is showing that though you treated the space, you didn't evidently get it in the right place for the big null and likely it wasn't thick enough to get that low in frequency.
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #8 of 15 Old 05-08-16, 12:21 PM Thread Starter
hemiutut wrote: View Post
Greetings.
I did not remove the plastic because I'm going to be returning the stuff. Plus I figured bass would just travel through thin plastic.
This was just a test to see if I'm going to spend real money on bass traps.
hemiutut likes this.
post #9 of 15 Old 05-08-16, 12:31 PM
bpape's Avatar
Bryan Pape
The plastic is fine on. When you have a layer like that it only restricts high frequencies. It acts somewhat like a membrane for the mids and lows. Where it stops absorbing depends on the density of the plastic.
Bryan Pape
bpape is offline
post #10 of 15 Old 05-08-16, 01:52 PM Thread Starter
bpape wrote: View Post
Thanks for all the help guys. I think the combination of my small room and Sound proofing has created a few peaks and nulls that can not be handled easily. I'm not really willing to pay the money needed for 4(or more) membrane tuned bass traps. I was hoping 9" thick ridged fiberglass panels with a 12" plus air gap would help below 100Hz in my room. My next test will be a multi "sub" test.
bass , bass trap , comfortboard is , fail , r6 , rigid fiberglass , roxul , test , trap
