GIK Acoustics DIY Acoustical Panel Build Thread - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
 10Likes
post #21 of 35 Old 11-08-16, 05:18 PM
ellisr63's Avatar
Ron
Re: GIK Acoustics DIY Acoustical Panel Build Thread
I am very curious as to how the denim works out... I have it stuffed in my soffits, and another bag or two behind my screen.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #22 of 35 Old 11-15-16, 01:06 AM Thread Starter
Wayne Myers
It has been an entire week since the last post. That is how slow I am at the upholstery attachment process. And only 1 of the 4 panels is done. Such is the world of DIY, you can get tripped up by the littlest thing.
No doubt there are a thousand guides for upholstery work online.
A finished frame with two trimmed Knauf panels in place.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161106_151514a-stuffed-frame-1.jpg
A side view. You can see the two Knauf panel thicknesses in this photo.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161106_151627a-stuffed-frame-2.jpg
Another side view.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161106_151706a-stuffed-frame-triangles.jpg
On a couple of the frame end-pieces, small cracks appeared where screws were inserted. A little wood glue and a C-clamp took care of that!
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161106_152306a-crack-clamp.jpg
With the upholstery cut into 4 pieces, one section was spread out and the first panel placed on it face-down.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161109_033155a-bed.jpg
Jo Ann's Fabric and Craft store had the upholstery tack strip. The other local hobby & craft stores did not.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161109_033511a-upholst-tack-strip.jpg
The tools and the process. This photo shows about a day's worth of work.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161109_050744a-stapled-edge.jpg
AudiocRaver is offline
post #23 of 35 Old 11-28-16, 01:10 PM Thread Starter
Wayne Myers
ALMOST DONE!
First I gotta admit that for me a DIY project ends up being a little like parenting. Four panels -- four kids. For the first panel, everything had to be perfect. By the time I was finishing the fourth panel, I just wanted it done and out of the way already! Write when you get work! But I digress...
The Wall. This wall has been through so many changes and transitions over the last four years, wish I had pics of every phase. I could make a fun time-elapse mini movie of the development process. All these will be forgotten, "like tears in the rain," sniff... Seriously, it has been a university of acoustics design down here in the Vibratorium. And it is exciting to be having it draw close to fruition. Notice I did not say done. Nothing is ever done down here.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_124031a-blank-wall.jpg
With two panels completed, time to add treatment to the wall itself. Since the GIK panels are destined to stand at an angle relative to the wall, I long ago decided to add some batting to the wall itself behind the panels. The second layer on the wall itself will add to the bass absorption. Rather than killing specific room modes, like we do with a tuned trap, the goal is mainly to dampen out the vibrations at those frequencies so the bass is tighter and SS&I improved. The Proof of Concept had already shown this to be a very effective strategy. Here are the two already finished panels, ready for the next step.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_144356a-ready-stuff-wall.jpg
A simple framework will hold the batting in place. The vertical wood pieces will clamp it against the wall, letting it fluff loosly at middle and ends.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_194313a-frame-wall.jpg
Working on getting the batting into place.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_200912a-stuffing-wall.jpg
The wall frame and batting as planned.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_202402a-wall-stuffed.jpg
The vertical clamping bars did not quite snug all the way down, that would have been too tight. Not to worry, though, that bating is not going anywhere.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_202704a-screw-depth.jpg
Getting ready for a listening test with the first two panels.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161124_204202a-wide-angle.jpg
I have ordered an additional yard of the same fabric from GIK to dress up the wall frame. It will look much nicer! With the batting in place on the wall, the two finished panels were set up for a quick test. The song that had been going through my head - Sleep Is Wrong - Sleepytime Gorilla Museum - was first played. Sounds good! But - So Far Away - Dire Straits - and - Black Hole Sun - Soundgarden - were far better demo songs for the effectiveness of the treatment. Scuse me, gotta pause to wipe a few tears...
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161126_162729a-2-panels-backdrop.jpg
post #24 of 35 Old 11-28-16, 01:37 PM Thread Starter
Wayne Myers
Last two panels. These would each hold a layer of the Knauf panel and a layer of the much-thicker UltraTouch batting. A couple of slats were glued into place for support so the UltraTouch did not push the Knauf panel through the front.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161127_140935a-supports-big-view.jpg
Moving quickly now, stapling the fabric into place more simply than before, the upholstery support strip was nice but took forever.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161127_140955a-support-boards.jpg
Horizontal strips of the batting were cut.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161127_150907a-mostly-stuffed.jpg
All three pieces in place, they fit just right.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161127_150945a-all-stuffed.jpg
Backside of a panel the GIK way.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161128_104517a-skinny-back.jpg
Backside of a panel the OTHER way, with thicker UltraTouch layer added. Not near as pretty. Oh, well. The left-over upholstery strip ended up acting like suspenders, holding the batting in place. And the finger is holding the camera in place - oops!
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161128_104619a-fat-back-straps.jpg
Closeups.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161128_104556a-straps-close-up.jpg
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161128_104549a-close-up.jpg
A comparison of the two approaches, rear view.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161128_104706a-2-backs.jpg
All in place and ready for another listening test. The slight lean-back gave a very slight improvement in SS&I. There ARE small reflections coming off of the front of those panels. The horizontal and vertical angles are chosen to direct those reflections away from the LP. The result? Nirvana! My phone will be on silent for a few days, don't bother me!
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161128_110324a-all-up.jpg
post #25 of 35 Old 11-30-16, 09:47 AM
Quenten
Is this the front wall, & between the front speakers? Sorry if you states this earlier, don't remember. Can we see a pic that's wide enough to see the speakers in it?
Tonto is offline
post #26 of 35 Old 11-30-16, 11:29 AM
ellisr63's Avatar
Ron
Looking great Wayne! When I made mine I used Roxul (4" total thickness per panel), and used 1"x4" for the frame. I then made a ledge for the rear of the panel so when I pushed the Roxul in it went flush to the rear. I also picked up some cheap cotton material from Jo Annes, and stapled that to the rear of the panels to keep everything nice and sanitary. My panels ended up with the Roxul sticking out the front a bit, but it gave me a rounded/angled corner which works out well in my situation...plus it sits flush against the wall. Now I know some people suggest spacing the panels out from the wall to make them more effective, but I didn't. Have you tried that to see how it effects the sound? I also found that Redwood works better than Pine (IMO) as it is lighter, and safer for first reflection panels hanging over your head. In hindsight I would make all my panels from Redwood (currently only the ceiling ones are redwood), but we learn from our DIY projects.
Are you going to test out to see if the holes on the side of the panels make a difference vs solid sides?
ellisr63 is offline
post #27 of 35 Old 11-30-16, 05:59 PM Thread Starter
Wayne Myers
Tonto wrote: View Post
OK, it's a little embarrassing to show that much of the turmoil of the room, but here it is. The speakers are the older MartinLogan ESLs, on the left and right sides of the picture, in what I consider a mid-field configuration, partly driven by the room and partly by personal preference. Dimensions: A=LP-to-speaker-plane=45in; B=center-to-center-of-the-electrostatic-panels=67in; speaker-plane-to-wall=64in; C=LP-to-wall=109in; the width of the front wall being covered by the leaning GIK panekls is about 5.5 ft.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161130_171947awideviewwspeakers.jpg
And of course a BIG thanks to GIK for the great kits and the great design.
GIK Acoustics DIY Acoustical Panel Build Thread-img_20161130_172250a-gik-_logo.jpg
post #28 of 35 Old 11-30-16, 06:12 PM Thread Starter
Wayne Myers
ellisr63 wrote: View Post
Yes, it does make the panel absorption more effective and primarily helps tighten up the bass and sharpen the soundstage. Standing the panels at the angle shown with the small amount of reflection going back to the speaker and not toward the LP makes a BIG difference in the image clarity and the sharpening of the soundstage. In my opinion, it is a major point of the design.
Cool idea on the redwood, probably looks sharp too.
Nope, bigger fish to fry. I doubt it would make a difference.
Tonto, Savjac and ellisr63 like this.
post #29 of 35 Old 11-30-16, 09:29 PM Thread Starter
Wayne Myers
Here is a rough diagram of the room layout, with dimensions.
I do need to take some REW measurements. I wanted to get a few before adding the batting on the front wall, then forgot. No way am I going to take that down just for a few measurements. I will get what I can.
post #30 of 35 Old 11-30-16, 10:03 PM
ellisr63's Avatar
Ron
AudiocRaver wrote: View Post
Attachment 132434
Funny that you mention that as I was just talking with a friend of mine earlier today, and we both agree that the front wall placement of acoustic panels made a bigger improvement in getting our setups sounding right than the first reflection panels did. In my friends setup he is listening in nearfield vs my 12' MLP.
ellisr63 is offline
acoustical , acoustics , build , diy , gik , panel , thread
