QRDude - Diffuser Calculator - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 18 Old 06-15-10, 02:07 AM
Chris
Re: QRDude - Diffuser Calculator
Hello Collo
The Diffuser Calculator is a really nice tool, which I came across a while back. In it you specify a minimum seating distance. What determines this? As I have a small room distances are not enough to have a diffuser going to lower frequencies. What happens if the minimum seating distance is not adhered to?
rgds
Chris
Chriswil is offline
post #12 of 18 Old 06-15-10, 02:48 AM Thread Starter
collo's Avatar
Collo
The minimum distance is based on three times the lowest wavelength diffused. This is an industry convention, but Ethan Weiner reckons you can be closer and still get benefits. He has some videos on his Realtraps site that let you hear the difference
Ports Rule ...
collo is offline
post #13 of 18 Old 06-15-10, 04:31 AM
Chris
I don't understand why it should be 3 x the wavelength of the lowest frequency, why not 1 x? Do you have any practical experience with this?
Chriswil is offline
post #14 of 18 Old 06-15-10, 06:51 PM Thread Starter
collo's Avatar
Collo
The response from the panel is made up of cancellations and re-inforcements due to the energy exiting each of the wells at a different phase. My understanding is that it takes a few cycles for this to settle into a stable wavefront.
See my optional reading panel on huygens principle of diffusion in the Technical overview of QRDs for the drawing.
I had a quick look for the 3 wavelength rule, but couldn't find it. Google is your friend there.
As for experience, I haven't done any installations, thus the referral to industry experts like Ethan, or the guys from GIK.
Ports Rule ...
collo is offline
post #15 of 18 Old 07-04-10, 02:11 PM
Hi Collo,
Great program!
In Cox and D'Antonio they state that the QRD design assumes a far field (9.9 But ...) and that this is defined as the region where the min and max path length to the diffuser/receiver is less than half a wave length (8.4.1 Near and far field). Using this definition the critical wavelengths are associated with the high frequencies and not the low ones. See equation 8.35: distance > (diffuser_width/2)^2/wave_length.
Markus
MarkusBonk is offline
post #16 of 18 Old 07-04-10, 06:31 PM Thread Starter
collo's Avatar
Collo
Thanks for those comments Marcus. you have inspired me to look a bit further....
Your information does indeed define what constitutes the "far field", however most listening is within the near field.
Here is the Google books display of the section in the Cox and D'Antonio book that gives the 3 wavelength rule. (Section 2.2.1)
Rather than give a proof, they state that "Precedence has shown"... suggesting that the rule was derived from their extensive testing experience.
Ports Rule ...
collo is offline
post #17 of 18 Old 07-05-10, 11:58 AM
Hi Collo,
collo wrote: View Post
That does appear to be one one of the limitations of the design. Have you put your mind around Schroeder's proposed solution to the near / far field problem? If one was to 'modulate the the well depths to follow a parabolic concave mirror' as suggested by Cox and D'Antonio where would one but the focal point? At the listening position? at 3 time the wavelength? The opposite wall?
Markus
post #18 of 18 Old 07-05-10, 08:46 PM Thread Starter
collo's Avatar
Collo
Such an approach would be impractical for most rooms.
Also, the situation changes with the angle of incidence of the incoming signal, as pointed out at the end of section 8.4.1
I couldn't see the point of trying to focus the sound to one region, when it's diffusion we are after...
Ports Rule ...
collo is offline
qrdude
