First room measurement..advice needed from newby - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 16 Old 10-12-10, 03:33 AM Thread Starter
Hello,
finally managed to take some first measurements, enclosed my results, using REW and the radioshack SPL,
with dolby sorround giving the sweep on all speakers
same volume settings etc. with thx
and the waterfall
First room measurement..advice needed from newby-oct-11th-dolby-waterfall.jpg
would be greatful for tips which ones (peak at 30hz, low at 35 Hz) to treat, would a helmholtz do the job, do they work for lows at well ?
How do you measure a typical cinema setup, using fronts/sub only or using all speakers? Quite suprised I get so different results on the bass level switching between dolby and thx...
Regards
Daniel
Daniel0012 is offline
post #2 of 16 Old 10-12-10, 07:02 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Re: First room measurement..advice needed from newby
Not perfect but I've seen a lot worse.
30 and 35Hz are going to be very difficult to deal with via treatment. I'd suggest working with mic position to see if you can help with small seating position changes. If you can't, or another problem them pops up, I'd consider using the RTA function of REW to play with sub position to try to smooth it out.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #3 of 16 Old 10-12-10, 07:51 AM Thread Starter
Thanks Brian,
good to get some expert judgement on how to focus before building lots of resonators and stuff, will try playing around with sub position first, any hints where a good position might be? Between the fronts wont work due to size and the the thing is heavy ;-) Will a sub equalizer/BFD do a good job, they seem a comparable cheap solution ?
Regards
Kino.pdf
post #4 of 16 Old 10-12-10, 08:11 AM
bpape's Avatar
Bryan Pape
I'd play with seating position first if possible.
Experimentation is best for sub positioning and you can use the RTA function in REW to help you.
EQ may be needed but only after exhausting seating and sub positioning. 35hz and down is very hard to do even with tuned absorbers as many times, when tuned that low, they can cause their own problems.
I'd also recommend doubling or tripling the thickness of the absorbers on the rear wall behind your seating. 5cm isn't enough to approach the deeper bass. Its' still not going to go to 35hz fully but it may help a bit and will definitely help with other things.
Bryan
Bryan Pape
bpape is offline
post #5 of 16 Old 10-12-10, 11:52 AM
MatrixDweller's Avatar
Zip
I found that when I moved my sub around it changed where the dips were, although they still existed. So you might be able to move your sub into a position so that the dip occurs at a lower frequency that is not as audible or to a higher frequency where it is more treatable.
Most people tend to recommend super chunks in corners and as thick as possible. That will help with the waterfall graph's representation of room decay and might alleviate some of the frequency anomalies. The end result is to minimize the room's colorization of the sound. Of course your speakers and/or AVR will have their own colorization. You could add in EQ to tackle things once you've made some improvements to the room.
MatrixDweller is offline
post #6 of 16 Old 10-12-10, 01:57 PM
marty1's Avatar
I have spent a lot of time trying to get as flatter response as possible, I have managed to get a fairly good response from subwoofer, the upper frequencies I am yet to tackle with room treatment.
I would advise picking where you would like to sit first, ideally away from walls and the centre of the room. Put the mic there and measure the sub in every possible position with any eq on amp or sub switched off, unplug the speakers and measure just the subs response alone in each position. Set the sweep from 10hz-200hz, 512k.
Compare your results and look for the best result, as close to flat as possible. Once you have that position sorted out start adjusting subs phase and peq (if available) to tweak any peaks, dips in the lower hz levels are pretty much only dealt with by sub placement so just try and bring the peaks down.
Regards
Marty
P.S. When you Measure speakers aswell set amp to stereo not dolby surround as it overcomplicates measurements, do not worry about rears just try and get 2 front mains and sub perfected first
marty1 is offline
post #7 of 16 Old 10-13-10, 06:20 AM
lesmor
As a novice I concentrated too much on the sub and graphs in one seating position
Perhaps there should be a room/seating/ sub setup guide . as I too found you should try and find the flattest seating position.
I positioned sub as best I could , then I run a line down the centre lenght of the room taking readings with the meter up and down the line until I found the best/ flattest seating position.
You could then try and fine tune by moving sub slightly . I didnt need to.
As always every room will be different but there has to be a better way then lugging subs around doing your back in.
Far easier to move the meter
lesmor is offline
post #8 of 16 Old 10-13-10, 07:04 AM Thread Starter
Thanks guys, this has been tremendously helpful so far, especially the hint just connecting the sw and runnung up 200hz helped a lot.
problem is, the sw ist just fine were it was, assuming i will run it up to 80 hz anyway (few other otions to place it anyway, bit too bulky)
problem are the fronts, these seem to drive most resonances, and there's just no other way to place them
well, altoghether looks a lot better then before playing a bit around with positions and sw settings, plus some thicker panels for the back already ordered but haven't arrived yet, I hope that will do the yob, what do you think
txs again
Daniel
btw.: great fun, playing around with REW, still the impact of running thx, dolby etc. keeps me quite frustrated, all of them at least on my receiver don't seem to change things for better
post #9 of 16 Old 10-13-10, 04:23 PM
marty1's Avatar
Try using 1/3 octave smoothing and click on measured at the top of rew graph, I think it makes the response a bit clearer.
Again measure with your amps sound settings set to stereo, not surround, with any eq on your amp or your sub switched off.
It is important you get everything correctly balanced before adding any eq.
Do a measurement for sub and speakers combined, phase on sub set at 0, then move phase dial 1 step measure again then move it again and again until the dial has done a complete 360, then compare the results, that dip around 50hz you have is more than likely a phase issue so this again will allow you to determine the best position for the phase dial.
Just out of curiousity, do you have your amps crossover set at 80hz, the subs crossover fully open and speakers set to small?
marty1 is offline
post #10 of 16 Old 10-14-10, 02:25 AM Thread Starter
Thumbs up Re: First room measurement..advice needed from newby
Thanks Marty for taking care of this
enclosed the smoothed graph
will try that, haven't changed the phase yet, will try if that further improves.
I have the SW open for the measurement only since I do all the digital processing on the BD-Player and run the Amplifier pure analog via Ext-in when watching movies (I don't use the amplifiers digital section) In my normal setup I have the fronts on large (The Logans go down well w´below 30 HZ) and the other speakers on small, SW crossover at 80Hz. Thus the 100hz distortin should dissapear, but cant really measure that.
Can you use REW for pure recording as well without using it as a signal? then I could try the setup with a test-dvd I have at hands using the BD-Player.
BTW, I will try not to use any EQ, I am more of an analog guy, believe in good analag equipment, even if its old stuff. So I really would like to smooth this out with room acoustics and placement, still some free space on the wall to add more foam ;-)
If the drop at 100hz stays, do you think a helmholtz or plate resonator would be an option?
Txs again
Daniel
measurement..advice , needed , newby , room
