THX Style Baffle Walls for AT Screens - Page 18 - Home Theater Forum and Systems - HomeTheaterShack.com
post #171 of 181 Old 03-19-11, 08:15 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Re: THX Style Baffle Walls for AT Screens
Good one.. Take lots of pics..
I made a further improvement to the Baffle Wall last night..
My construction leaves an opening at the top and bottom..no perimeter frame..
Whilst the bottom opening goes down to the floor carpet, the top opening goes up to the plasterboard ceiling..
I felt that this might tend to reflect some of the higher frequencies and interact with the front wave to some degree..so I fitted some convoluted foam on top of the wall, covering the open area..
I noticed an improvement straight away with a much smoother mid to high frequency response..
Voice clarity improved as well..
I watched Iron Man 2 and in this movie, Tony Stark (as his character depicts) regularly tries to talk over everyone else and rapidly and you're trying to hear two conversations going on at the same time..
I noticed that I was able, for the most part, to clearly hear each word in both conversations..
There is also some drum beats in the movie and they came through very strongly and clearly..
The Baffle Wall just gets better and better!!
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #172 of 181 Old 03-20-11, 05:38 AM Thread Starter
Mark Techer
I noticed that on your pics and wondered if that would cause you any issue. Clearly it did and you resolved it quickly. Well done.
Mark Techer is offline
post #173 of 181 Old 03-20-11, 05:31 PM
Prof.'s Avatar
The Mad Professor
Thanks Mark..The fronts are now sounding like I've expected them to sound..
The sub on the other hand is still not completely to my satisfaction..I'm very limited for placement as the sub sits on a sand filled base..
I may have to get an Antimode 8033 EQ unit to balance out the lower frequencies..
Prof..
Prof. is offline
post #174 of 181 Old 03-27-12, 11:32 PM
Mike
I have a question I hope someone can answer. I was planning on using 2" OC703 covered in black cloth on the wall behind my AT screen but stumbled onto this Baffle wall discussion. Would that be close to the same as a baffle wall?
sub_crazy is offline
post #175 of 181 Old 02-26-14, 10:44 PM
nathan_h
sub_crazy wrote: View Post
Old question, but in case someone is reading excellent thread....the answer is: Not really unless the speaker faces are flush with the front of the OC703.....and more important there's a solid wall behind the OC in which the speakers are mounted. It's really about the solid wall, and less about the damping on it.
nathan_h is offline
post #176 of 181 Old 03-24-14, 01:52 AM
ellisr63's Avatar
Ron
How do I know if a baffle wall is the way for me to go? I have JBL 2360 horns and custom bass bins, La Scala bass bin center with EV horn and a DTS-10 sub that are going behind a 18' wide AT screen wall. None of the speakers are ported and all but the sub and the custom bass bins will be right up against the screen or a least within 6" of it. The sub will be firing 2-3' behind the wall and the custom bass bins are shaped like a pie with the curved area facing the center and screen area.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #177 of 181 Old 03-25-14, 08:41 PM
nathan_h
ellisr63 wrote: View Post
One of the biggest reasons for them: Increasing speaker output (more SPL). Do you need more SPL? (Doesn't seem like you would, based on what you describe! )
nathan_h is offline
post #178 of 181 Old 03-25-14, 09:07 PM
ellisr63's Avatar
Ron
nathan_h wrote: View Post
112db with 1 watt at 1 meter... I don't think I need more SPL. I think I could hit reference levels with a headphone amp on the horns.
ellisr63 is offline
post #179 of 181 Old 03-25-14, 10:22 PM
nathan_h
Okay so the other reason often cited for a baffle wall is to reduce diffraction, for clearer sound. But especially if one tries to get fancy and not have a flat wall, it is apparently easy to do more harm than good.
nathan_h is offline
post #180 of 181 Old 03-25-14, 10:30 PM
ellisr63's Avatar
Ron
Do you mean it is easy to do more harm than good with a baffle wall?
ellisr63 is offline
baffle , screens , style , walls
