Dip at 75hz....need to build a membrane trap? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 06-18-12, 10:03 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Re: Dip at 75hz....need to build a membrane trap?
Think more centered behind you rather than the corner probably. Use something at least 6-8" thick.
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #12 of 14 Old 06-18-12, 11:06 AM Thread Starter
jlird808's Avatar
bpape wrote: View Post
I may have the perfect place! Unlike the room layout image I posted, that "curtain" behind me is actually two windows with blinds. BETWEEN THEM I have a wrapped 705 panel that is only 1.5" thick (but spaced off the wall about 1.5") at about 36"w x 44"h set on a waist-high bookshelf. I could easily add some more slabs of 705 to the back of this and make it 6-8" thick as u suggested. I could also technically make it taller but I couldn't really make it any wider.
I'll try to take a picture of this rear wall with the current 1.5" panel later this evening.
Thank you!!
C6 - W7 x64 - Custom AMD Phenom II x2 560 Black 3.3Ghz - 8gb DDR2 - EMU 1212M - UAD1 - GAP Pre 73 - HS80m's - Presonus HP4 - Yamaha KX49 - NI/IK Bundles
jlird808 is offline
post #13 of 14 Old 09-26-12, 08:26 PM Thread Starter
jlird808's Avatar
Popping back in here...gonna build a 6-8" slab this weekend.
One concern though, based on this pic of my back wall, is the area just TOO NARROW?
That 1.5" panel was just there to stop first reflections, as its about 10' behind my head. I can't make it any wider, but I can definitely make it THICKER and TALLER. The tops of those windows are actually about 10' up. The walls continue another 2' to the ceiling.
So would it be worth it to fatten up that trap on the back wall, seeing as how its relatively narrow? Make it go to the ceiling maybe?
Here's my floor plan again...again, the curtain is inaccurate, its not one long complete wall.
THANK YOU!!!!!
jlird808 is offline
post #14 of 14 Old 09-27-12, 07:31 AM
bpape's Avatar
Bryan Pape
Can't hurt. Not sure if you'll have enough surface area to be fully effective but it will still help the overall decay time in the room. I would look at a bare minimum of 6" thick. Thicker and/or spacing off the wall will help extend the reach farther.
Bryan
Bryan Pape
bpape is offline
75hzneed , build , dip , membrane , trap
