help with further construction off cinema / music room sloped front and rear wall - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 78 Old 04-28-13, 04:19 PM Thread Starter
Re: help with further construction off cinema / music room sloped front and rear wall
While i was further studying room treadment, i found this:
Highly Directional Speakers (horns, rear-absorbed electrostatics, ribbon panels)
With more direct than reflected sound placement is usually easier. Electrostatics and
ribbons with wider horizontal dispersion require greater care in placement.
Spaciousness: fair to good
Localization: fair to excellent
Actualy i am using horn speakers, so it could be possible that afterall there simply is not enough reflected sound (ambiance, spacines) anymore...( complete frontwall, first and second sidewall reflection points are already treated.)
mikesp1 is offline
post #32 of 78 Old 04-29-13, 05:48 AM Thread Starter
Well, i have my sound back!!! And i dont have t move to the front.
By turning the isolation ( i have a diffusor) in the first reflection zones so the aluminium is facing frontwards, i have my sound back, front stage is hugh, refind, voices are super, image is good, ambiance is greath and even bass and midbass are a lot better and refind.
One problem, i can hear the aluminium vibrate from time to times.
this is defenitly de way i have to go but need a solution for the vibrating aluminium.
if anyone as a solution i am curieus to know!
help with further construction off cinema / music room sloped front and rear wall-imag0020.jpg
mikesp1 is offline
post #33 of 78 Old 04-29-13, 08:17 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
remove the aluminum and cover with thin plastic - something like maybe 5 mil or so. That will still give you some highs back but be easier to stretch tighter.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #34 of 78 Old 04-29-13, 09:04 AM Thread Starter
Bryan thanks again for the recommandation, will try it tommorow.
I also did a quick test and covered the isolation with mdf, it gave not the same result as with the isolation covered with aluminium, i think the latter diffuses more...gives also some mid absorption aswell.
Sometimes you can not follow the standards, trial and error...
mikesp1 is offline
post #35 of 78 Old 05-02-13, 04:56 AM Thread Starter
Frontwall is almost done, i removed the resonating ply on the upper sloped ceilig and covered with fabric.
This made a huge difference!!!
In the second step i removed the resonating ply on the backwall aswell, behind the ply is 8" of isolation covered with plastic.
Soundwise this is even worse than before on the graph i can see that the huge dip on 120Hz has moved to 90Hz.
Should i cover the backwall less absorbing and cover with MDF or something?
Behind the lower backwall is some cavity, should i cover this also with MDF or use it later for maybe a pannel absorber?
Your help is much appreciated!
help with further construction off cinema / music room sloped front and rear wall-spl-ply-backwall-removed.jpg
help with further construction off cinema / music room sloped front and rear wall-waterfall-ply-backwall-removed.jpg
help with further construction off cinema / music room sloped front and rear wall-rt60-ply-backwall-removed.jpg
help with further construction off cinema / music room sloped front and rear wall-frontwall.jpg
help with further construction off cinema / music room sloped front and rear wall-ply-removed.jpg
help with further construction off cinema / music room sloped front and rear wall-cavity.jpg
mikesp1 is offline
post #36 of 78 Old 05-02-13, 07:39 AM
bpape's Avatar
Bryan Pape
Is the last picture your rear wall?
Bryan
Bryan Pape
bpape is offline
post #37 of 78 Old 05-02-13, 07:41 AM Thread Starter
yes, thats correct, 2 last pictures are rearwall
mikesp1 is offline
post #38 of 78 Old 05-02-13, 08:00 AM
bpape's Avatar
Bryan Pape
By removing the ply, you've essentially uncovered the 'horn' in the rear of the room. I think the absorption in the rear is still a good thing. I would try some MDF on the REAR (hidden) side of the rear wall. Cover the front(exposed) side of the insulation with some 5-10 mil plastic and then fabric.
Bryan Pape
bpape is offline
post #39 of 78 Old 05-02-13, 08:10 AM Thread Starter
Bryan,
"5-10 mil", do you mean milimeter?
mikesp1 is offline
post #40 of 78 Old 05-02-13, 08:14 AM Thread Starter
oh i see its 0.127 to 0.254 milimeter!
25,4 10-6 meter (0,0254 mm)
mikesp1 is offline
cinema , construction , front , music , rear , room , sloped , wall
