help with further construction off cinema / music room sloped front and rear wall - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 78 Old 05-14-13, 03:17 PM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Re: help with further construction off cinema / music room sloped front and rear wall
Front corners with chunks and the center of the back wall as thick as you can tolerate. Hold off on the other unless you need it.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #52 of 78 Old 05-14-13, 03:52 PM Thread Starter
Ok, backwall is 3.6m wide, 1.4m high, at 1.4 m the sloped ceiling begins ( wich we already treated by removing the ply, after the removed ply is 8" rockwool covered with plastic) so do i tread the entire lower backwall 3.6 x 1.4 or just, lets say 2m x1.4 m and leave the corners untreated?
Front wall is already treated with 24" superchuncks in corners and entire frontwall is made death as per your recommandations.
If i sit in the backwall corners, i do not feel any bass pressure at all.
mikesp1 is offline
post #53 of 78 Old 05-14-13, 04:17 PM
bpape's Avatar
Bryan Pape
Just do the 2m x 1.4m in the middle.
Bryan Pape
bpape is offline
post #54 of 78 Old 05-14-13, 05:37 PM
Jason
I tried a sub directly behind me as well and didn't like it. Everyone says you cannot localize under 80 Hz, but I can tell if a sub is directly behind me. Plotted well, sounded horrible.
Jason_Nolan is offline
post #55 of 78 Old 05-14-13, 05:44 PM
bpape's Avatar
Bryan Pape
turn the level down on the one behind you. Every meter closer you'll gain about 6db. You can also dial down the xover point on it to just be high enough to address the dip.
Bryan Pape
bpape is offline
post #56 of 78 Old 05-15-13, 04:51 AM Thread Starter
I agree, i can localise that sub behind me, even when i turn the volume much lower.
X over is on 80Hz for both subs, i will make a listen with the sub behind me on x-over 50Hz.
I tried with treadment on the backwall (blue curve), 1.5' of rockwool, 1.2m x 1.4m did maka things wurse!
All energy stays at front half of room, if i cross the midlle of the room there is not much pressure. This was before i made treatment and stays with treadment. it must be the type of room sloped ceilings on back and frontwall.
I do not know what to do anymore...
I think my best beth is to turn the volume on the front sub higher, so the 80hz dip is gone (yellow curve on graph) and then eq the peaks (maybe an antimode can do this?) from 50 to 70Hz and 20 to 40Hz.
help with further construction off cinema / music room sloped front and rear wall-rt60.jpg
mikesp1 is offline
post #57 of 78 Old 05-16-13, 03:45 AM Thread Starter
Todat i did a quick test with rockwool stacked in backcorners, again no benefit.
blue curve: starting point upper ply removed, lower ply untouced
green curve: no rockwool, upper ply removed, lower ply reinforced
red curve: rockwool in corners
As you can see rockwool in corners gives no benefit
help with further construction off cinema / music room sloped front and rear wall-1.jpg
mikesp1 is offline
post #58 of 78 Old 05-16-13, 03:54 AM Thread Starter
This curve was with lower ply totaly removed, it sounded much better in the low end, altough there are big dips on other frequencies.
Its getting verry frustrating after all the hard work getting no where.
help with further construction off cinema / music room sloped front and rear wall-2.jpg
mikesp1 is offline
post #59 of 78 Old 05-16-13, 07:08 AM Thread Starter
Well, today i did some further testing.
I played only with the two Klipsch Palladiums without sub.
It was a relieve, bass was so punchy, articulate.
I then A B'd with and without subwoofer, i can only say Without was so much better!
I think the sub's i am using are no match for the quality of the Palladiums...
Here is a graph of spl 1/24 octaaf with only the fronts:
If i could,bring those peaks at 55 and 100 Hz within 10db that would be a good starting point to move further and start with the blending of the subs...
help with further construction off cinema / music room sloped front and rear wall-image.jpg
mikesp1 is offline
post #60 of 78 Old 05-16-13, 08:27 AM Thread Starter
Waterfall
help with further construction off cinema / music room sloped front and rear wall-waterfall-mains-only.jpg
mikesp1 is offline
cinema , construction , front , music , rear , room , sloped , wall
