GIK Rec Rm. recomendation. - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 33 Old 01-08-14, 05:18 PM Thread Starter
John
Re: GIK Rec Rm. recomendation.
If I put 3 224's on the ceiling and 2 224's on the side walls would that be a big improvement ?
On bass traps , how effective are the soffit traps when not all the way in a corner ? One behind each front speaker ?
John N is offline
post #12 of 33 Old 01-09-14, 10:22 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Anything will help tame the decay times. I think the side walls are most important and available right now. 244's would be great. 242's at the ceiling reflections, absolutely.
Soffits, they'll still help but can't be as effective as they are in the corners. Remember though that they or the Tri Traps can be laid horizontally along the wall/floor junction also.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #13 of 33 Old 01-11-14, 08:49 PM Thread Starter
John
bpape wrote: View Post
Bryan
I received the white samples you sent , thanks !
I'm going to order 3 242's for the ceiling and because of ceiling height will want mount them close to ceiling.
Do you have a link to show best method ?
I will order 3 244's and put two on the right wall and one on the left . I bought 703 ? years ago from
sensiblesoundsolutions.com and will make a DIY panel to fit inside the left window.
I will add more bass traps to front wall and tackle the back of the room later.
Thanks for the info !!
John N is offline
post #14 of 33 Old 01-12-14, 10:17 AM
bpape's Avatar
Bryan Pape
Best way to hang tight from the ceiling is to just use 4 hooks in the ceiling directly to the eyes in the rear of the panel.
Bryan Pape
bpape is offline
post #15 of 33 Old 01-14-14, 08:48 PM
How is the sound in the back of the room? Or does it not matter too much with no one back there when playing stuff. It looked pretty lively and thought that might use some wooden diffusors or such.
yluko is offline
post #16 of 33 Old 01-15-14, 10:13 AM
bpape's Avatar
Bryan Pape
What would happen in the rear would depend on if there are any cancellations coming off that wall in the low end. If so, then thicker absorption would be ideal. If not, then you can maybe use diffusion.
Bryan Pape
bpape is offline
post #17 of 33 Old 01-15-14, 08:54 PM Thread Starter
John
yluko wrote: View Post
Right now the whole room is a "mess"
I ordered 3 242's for the ceiling over seating area .
When I figure out the color , I will be ordering 244's for side walls at first reflection points .
I'm starting at the front at working my way back
Because my sub (JTR orbit shifter ) is in the front left , there is a ton of "boom" behind the bar .
John N is offline
post #18 of 33 Old 01-15-14, 09:49 PM
I figured bass might congregate there. I have seen full circle type bass traps that don't even really look like them you could throw in the corner that might look nice and grab some of that buildup.
yluko is offline
post #19 of 33 Old 01-19-14, 05:03 PM Thread Starter
John
I ordered a "few " samples of the GOM Anchorage fabric. That stuff is really nice !
What is the upcharge per panel to use the anchorage fabric ?
John N is offline
post #20 of 33 Old 01-20-14, 08:52 AM
bpape's Avatar
Bryan Pape
It varies from $15-$30 per unit pending which product it is. Plus there is a one time $20 charge since it's not something we stock. Shipping and per yard pricing to us is not as good when not buying a full bolt.
Just understand it is not suitable for putting in front of a speaker. You'd want to go to the FR701 series for that purpose.
Bryan Pape
bpape is offline
gik , rec , recomendation , rm
