Diaphragm / Membrane Bass Traps - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 18 Old 04-03-14, 08:28 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Re: Diaphragm / Membrane Bass Traps
You're still talking 2 different things. If it's a non-sealed damped membrane, then the volume of the box doesn't matter, only the thickness and it should not have a back on it at all. If you ARE doing a sealed box with a back then it tunes narrowly.
No idea on 2lb high cut, sorry. 4lb MLV, not heard of it
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #12 of 18 Old 04-03-14, 08:41 AM Thread Starter
bpape wrote: View Post
My mistake, you mentioned sealed and unsealed earlier. I should have clarified: yes, I mean sealed. Here's an image to help explain the kind of box I'm talking about:
The brown is the wood, black is the membrane, and gray is some insulation. The rest is just air.
The membrane is pressed tightly to the wood, to make an air-tight seal. The box would have a top and bottom too, of course - thus, it's sealed.
Most of the box is shaped like a triangle, to fill up a corner of a room and (hopefully) increase the apparent depth.
The depth in the triangle area varies from 0" (left and right side of the triangle) to, let's say 8", at the center.
So, how would the depth be calculated in the triangle portion? Would it be 4"? (I need to put that into the calculator, to find the tuned frequency.)
If it's still not clear, I apologize.
icor1031 is offline
post #13 of 18 Old 04-03-14, 08:51 AM
bpape's Avatar
Bryan Pape
That's going to tune VERY narrowly. Figure the volume of that triangle plus the rectangular space and relate that to the volume of a rectangle the size of the face (gotta work backward).
Bryan Pape
bpape is offline
post #14 of 18 Old 04-03-14, 09:00 AM Thread Starter
The example above is 4" of insulation (though unstated and unscaled, lol). And unless I screwed up,
8" in that triangle should give 4" of volume if it were a rectangle the size of the face.
The blue one should mimic that.
The green one is an alternative design, with 200mm (8") insulation, with the triangle beginning 10" out from the corner. (5" worth of volume)
Does it look like I followed your directions correctly?
Thanks for your help!
icor1031 is offline
post #15 of 18 Old 04-03-14, 11:04 AM Thread Starter
I really like these two:
icor1031 is offline
post #16 of 18 Old 04-03-14, 02:59 PM
bpape's Avatar
Bryan Pape
and those are limp membranes, not sealed ones which is why they are broader. Damped limp membranes will be even broader on the bottom side but still roll off on the top side.
In the end, what you do should be based on what the room requires. Do you know that part yet?
Bryan Pape
bpape is offline
post #17 of 18 Old 04-03-14, 03:58 PM Thread Starter
Ah, . I don't want unsealed, because of the fibrosis possibility from the insulation. Unless putting 2mil plastic over the insulation won't ruin the affect in this kind of design?
I don't suppose you know of a calculator that shows the response like this does, for a sealed membrane resonator?
Also, no - I don't know what I need yet. I have a proper measurement mic. It's calibrated, not that it needed to be. However, I'm moving in about a month - and I'll be able to take measurements shortly.
icor1031 is offline
post #18 of 18 Old 04-03-14, 04:13 PM
bpape's Avatar
Bryan Pape
Other than mine that I use to design our Scops Traps, nothing - but the formulas are available on the web.
Bryan Pape
bpape is offline
bass , diaphragm , membrane , traps
