DIY absorbsion panels - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 13 Old 07-23-14, 02:59 PM Thread Starter
r.kuenen's Avatar
I want to make a start to make my own absorbsion panels.
I read a lot about them and wanted to start with some basic panels made from Roxul Safe and Sound. My problem is that where i live (the Netherlands) the have no Roxul, the Dutch company is called Rockwool.
Unfortunately, they have no panels with that name. So i called a Rockwool account manager to ask what i could use that came as close as possible to the 'safe and sound'. He said that i need the 212 (http://rwiumbracobn.inforce.dk/media...aat_212_nl.pdf). The problem is that i must order a batch and the construction company's rearly use this.
What could i use as alternative for 70mm Safe and Sound? Should i (besides the thickness) just look at the weight per m3?
Some peaple say i should use glasswool like This
I'm confused with the many differend products rockwool has, and i can't find any absorption numbers in the specs.
Who can help me with this?
r.kuenen is offline
post #2 of 13 Old 07-24-14, 09:05 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Re: DIY absorbsion panels
Either can work pending the density. You want in most cases something equivalent to 3lb/cu ft.
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #3 of 13 Old 02-10-15, 01:07 PM
Would eggcrete/foam and rockwool work?
DigitalNinja is offline
post #4 of 13 Old 02-10-15, 01:29 PM
bpape's Avatar
Bryan Pape
Skip the foam - basically worthless. Rockwool can work if the right density. Just a pain to cut and work with.
Bryan Pape
bpape is offline
post #5 of 13 Old 03-13-15, 01:38 PM
New Member
iwonB
some wooden stuff with rockwool
iwonb is offline
post #6 of 13 Old 03-21-15, 12:57 PM
I hope I'm not stepping on toes by posting this here but it seemed to be a good place to avoid somewhat duplicate threads.
I'm building some 24" X 48" absorption panels which will use 1 X 4 frames and have the Rockwool 60 2" thick panels covered with Burlap.
Some videos I've sees show the rockwool panels being stuffed inside thin plastic bags before covering to insure the fibers don't escape.
I am considering using Drycleaning bags.
good idea?
bad idea?
doesn't matter?
TheGimp is offline
post #7 of 13 Old 03-21-15, 02:00 PM
robbo266317's Avatar
bigbadbill
That should be fine as long as they are very light.
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
post #8 of 13 Old 03-21-15, 02:09 PM
ellisr63's Avatar
Ron
TheGimp wrote: View Post
good idea?
bad idea?
doesn't matter?
Are you using (2) 2" thick for each panel, or just one? We used (2) 2" thick Roxul R80 panels for each first reflection point and it worked great.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #9 of 13 Old 03-21-15, 03:53 PM
1 - 2" thick for each panel.
I may have to buy another box of acoustic panels.
TheGimp is offline
post #10 of 13 Old 03-21-15, 04:35 PM
New Member
Ståle
Hi
Try cloth used by gardeners underneath barque
Vessel56 is offline
absorbsion , diy , panels
