-   Home Audio Acoustics (https://www.hometheatershack.com/forums/home-audio-acoustics/)
-   -   What type of diffuser goes on the back wall? (https://www.hometheatershack.com/forums/home-audio-acoustics/145265-what-type-diffuser-goes-back-wall.html)
jmtenthusiast 03-10-16 10:42 AM
What type of diffuser goes on the back wall? In other words, what frequencies will I build for, low to high?
http://www.mh-audio.nl/DiffusorCalculator.asp
The front wall is 3" rockwool, sides will be with rockwool as well as ceiling. 1/2 of the back wall is 3" rockwool.
Dimensions of room, 8 ' ceiling, 12 feet wide, 20' in depth.
Thanks!
bpape 03-10-16 10:53 AM
Re: What type of diffuser goes on the back wall?
What is the room going to be used for? HT? 2 channel? Studio? I assume HT?
jmtenthusiast 03-10-16 11:52 AM
Home Theater
jmtenthusiast 03-10-16 11:56 AM
2 Attachment(s)
Diffuser will go at the top of the garage door.
bpape 03-10-16 11:57 AM
Up there it's more for flutter echo so I would build for higher frequencies.
jmtenthusiast 03-10-16 12:03 PM
bpape wrote: (Post 1408665)
Up there is's more for flutter echo so I would build for higher frequencies.
What's considered higher frequencies?
Also, would it be a better idea to move the absorption panel to the top and put the diffuser at the 2/3rd's spot? If so, would I build diffuser for different frequencies?
jmtenthusiast 03-10-16 12:16 PM
How far behind my AT screen should my speakers be? 2"? 6"?
ellisr63 03-10-16 01:14 PM
Are you leaving the garage door as functional? We stuffed ours with insulation, and screwed it together to stop it from vibrating. We also built a fake wall up in front of it and stuffed it with insulation.
jmtenthusiast 03-10-16 01:55 PM
ellisr63 wrote: (Post 1408753)
Yes, it will be functional.
jmtenthusiast 03-10-16 02:33 PM
What do you consider "higher" frequencies? Is it 500 to 20K?
