-   Home Audio Acoustics (https://www.hometheatershack.com/forums/home-audio-acoustics/)
-   -   Trying to Fix Center+Sub FR (https://www.hometheatershack.com/forums/home-audio-acoustics/166274-trying-fix-center-sub-fr.html)
Lumen 03-06-17 02:14 PM
4 Attachment(s)
My center channel sits on the top shelf of an A/V rack beneath my display about 2.5 feet from the front wall.
Running full system sweeps per pg.100 of the REW Step by Step Guide, I generated the graphs below for the center only, and for center+sub. There's a large dip centered around 100Hz that I think is due to SBIR; [ fc = c/4dwall = 112.5Hz ], so that would need to be addressed first.
Any help to understand or solve these issues are greatly appreciated!
  1. What are the reasons for the dips close to 200Hz and 400Hz?
  2. Why does the FR have a rising trend? Room gain?
  3. Does sub phase need to be adjusted to provide good SPL support through the xover region for both the mains AND the center simultaneously? IOW, if it's good for the mains, is it good for the center?
  4. Would an external time delay (my AVR disables them when using Dirac) make my sub play nicely with both mains and center?
Attachment 138098 Attachment 138106
Attachment 138114 Attachment 138122
bpape 03-06-17 02:43 PM
Re: Trying to Fix Center+Sub FR
Sub level looks a little low. Where are you crossing mains to the sub? If it's 90-100 then the dip there could absolutely be the culprit.
200 and 400 could be SBIR from front wall, side walls, ceiling, etc.
Lumen 03-07-17 08:12 AM
bpape wrote: (Post 1561938)
Thanks for your quick response, Bryan! The sub level for the Center+Subs measurement is low because I needed to reduce REW's input level to avoid clipping.
Good question! The measurements were taken with auto-EQ disabled, so I thought bass management was as well. Now I'm unsure how my processor handles crossovers. I do know that its Dirac Live LE feature uses non-adjustable 80Hz crossovers - yes, that's a peculiarity of Dirac Live for Emotiva (LE). So I looked it up on pg.53 of the manual, and found that when certain playback modes are active, so is bass management. This simple functionality didn't occur to me before, so I have no idea at what point the crossovers were set! I will need to look them up in the processor's menu system when I get home.
Phillips 03-07-17 12:22 PM
Lumen wrote: (Post 1562129)
I think he meant the sub level itself is low.
bpape 03-07-17 12:32 PM
Yes - exactly. The sub isn't balanced to the mains.
Lumen 03-07-17 02:17 PM
That's a mystery to me, and I believe you, but how can you tell without an mdat or a sub-only graph?
bpape 03-07-17 02:35 PM
Just look at the general level compared to 80 and above.
willis7469 03-07-17 02:42 PM
Lumen wrote: (Post 1562305)
This was kinda my question in the other thread. You mentioned reducing the sub level for REW , and it looked like a rise up to 70ish. Curious, why not just lower the MV?
bpape 03-07-17 02:54 PM
Either will work.
Lumen 03-08-17 07:53 AM
willis7469 wrote: (Post 1562329)
bpape wrote: (Post 1562337)
Either will work.
I'm getting old... my memory fails me. I thought I had reduced the soundcard's input level to avoid clipping, not the sub's output, but I can't find the post now. I'm making such a big deal about it because I'm thinking I should have taken all measurements over again, not just CENTER+SUB. Then the relative levels between graphs would synch up.
But you're not talking about relative levels between graphs, are you? I think I finally get it - you're saying the sub's level should be brought up to match the mains, correct? I was not aware of this system tuning step, so I always left it up to auto-EQ. Yet it makes sense to correct as much as possible before auto-EQ to reduce audible artifacts resulting from too many filters.
