-   Home Audio Acoustics (https://www.hometheatershack.com/forums/home-audio-acoustics/)
-   -   Phase 1 -- Planning (https://www.hometheatershack.com/forums/home-audio-acoustics/32961-phase-1-planning.html)
bpape 09-24-10 04:58 PM
Re: Phase 1 -- Planning
My bad. Thought you were going AT.
That said, you shouldn't let screen size drive seating location. If you need/want AT then put the seats where they need to go acoustically and size the screen accordingly. Setting screen size first is kinda backward IMO.
You have close to 18' to play with. I've done rooms with AT screens that size that had 2 rows of seating and they were in good places and not up against a wall.
Nothing wrong with non-AT certainly. Just making sure you're going through the right decision sequence.
Bryan
Bryan
4U2NVME 09-24-10 06:58 PM
bpape wrote: (Post 293623)
Bryan
Ok Bryan,
I feel like a coin lol going between heads and tails. After chatting with you, I'm going back to the AT version. Its really what I wanted anyways, and I'll check out the screen widths to see if I can squeeze a bit more then the 100" width. I'll shoot for a 40deg viewing angle front row and see what it comes out as.
-NV
4U2NVME 09-24-10 07:43 PM
I will post up the first live picture of my HT, there is still a bit of work to do, lots os ambient noise going on and the HVAC currently is a nightmare. I'm a few months away from having the build complete, but you can just start to see how it all will work out. :R
http://i172.photobucket.com/albums/w...G_7484Copy.jpg
steely 10-28-10 05:26 PM
4U2NVME wrote: (Post 291396)
Hi Brad
So are you actually currently building your house? If so, you might want to pay attention to the plumbing attached to the wall joining the theatre. It won't take much noise from the toilet flushing/refilling or faucets running to be a distraction - a rule of thumb is to avoid plumbing being attached to a wall of a sensitive space.
So if possible, reorient the bathroom so that plumbing is in another wall, if this is not possible you can do the following: If using copper piping, explain to the plumber that noise is of a concern and ask if they can pay attention to removing burrs left after cutting the piping, a good plumber should be doing this anyway. The second step is to isolate the framework when run through stud walls by mounting the pipe clips on felt or rubber pads. The sound of water flowing through the pipes is amplified by the plasterboard studwork, so avoid hard shorts where possible. The third step is choose a cistern float valve that is low-noise, one brand you can look at is Torbeck.
-Andrew
4U2NVME 10-28-10 11:26 PM
Thanks Steely! I have talked with the builder and have asked him to route all drain pipes etc away from the ceiling of the HT. The HT does back onto the mechanical room. I hope it does not become to big of an issue. I can ask that all plumbing fixtures etc be located on the other side of the Mechanical room.
Brad.
