-   Home Audio Acoustics (https://www.hometheatershack.com/forums/home-audio-acoustics/)
-   -   anything wrong with putting tower speakers on the TV stand? (https://www.hometheatershack.com/forums/home-audio-acoustics/73880-anything-wrong-putting-tower-speakers-tv-stand.html)
dannieboiz 03-15-14 04:57 PM
Is there anything wrong with putting tower speakers on the TV stands?
my TV is actually hung on the wall, speakers are mythos one towers. Thinking about getting a 75" media console and placing the towers on top of the console. Cosmetically I think it might look ok, maybe even better than on the ground since my TV is hung a little higher and the speakers will be elevated to almost match the TV
tonyvdb 03-15-14 05:02 PM
Re: anything wrong with putting tower speakers on the TV stand?
Ideally you want tower speakers away from the wall at least a foot but sometimes that's not possible. Are they rear ported?
nova 03-15-14 05:05 PM
You would also want the tweeter to be about ear level as well.
dannieboiz 03-15-14 05:13 PM
Speakers aren't ported and I see no difference in sound weather I push it against the wall or a foot and a half away.
Tweeters on the other hand would be at ear level only if I'm standing. it'll end up being 3 ft or so above the ears 8 - 10 ft away from sitting area.
ellisr63 03-15-14 05:44 PM
dannieboiz wrote: (Post 689412)
I would say that is too high...
tonyvdb 03-15-14 05:50 PM
I agree it's quite high, what is the shelf made of as vibration may be an issue.
dannieboiz 03-15-14 05:57 PM
tonyvdb wrote: (Post 689425)
I have not picked one out yet but it'll be all wood. most likely plywood. The speaker itself is not a very large by design. I can see where a large array of 6.5" or 8" speakers can be problematic.
http://www.crutchfield.com/S-LMeRG4E...ythos-One.html
MikeBiker 03-15-14 06:07 PM
It is important to have the tweeters near ear level. The closer to the speaker that you sit, the more important this is. I would also be concerned with the tower not being on a firm surface.
dannieboiz 03-15-14 06:10 PM
MikeBiker wrote: (Post 689435)
Sounds like this is not very favorable to most, I might scratch it off and get a small cabinet and sleep better at night. :D
buildsafire 03-15-14 06:56 PM
I would definitely not recommend having the tweeters that high above seated listening level. I second that, as well as the safety/Isolation of the speakers on a TV Stand... Good luck! Sorry for reiterating what has already been stated, but I do think that you would be sorry you set it up that way.
Sent From My S4 Via HTS App
