Pioneer AJ or Sony Cores?? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 12 Old 09-12-19, 10:40 PM Thread Starter
The_Nephilim's Avatar
Gerald
Re: Pioneer AJ or Sony Cores??
Hi All,
Well I finally pulled the trigger on the Premier Acoustic Titanium Fronts PA-6F's and center PA-6S.. I did have 1 question tho.the Terminal cups have 4 binding posts with a metal bridge connector..
I am wondering are these Bi-Wire speakers or something because I was looking at Parts express for a Terminal cups and found the 4 binding post terminal like mine and it said for Bi-Wire speakers.
I just want to be sure I hooked them up correct but what I did was connect the speaker wire and left the jumper in place.. I know for the Bi-wire you are supposed to remove the jumper and run two sets of wires from the receiver to the speakers and in the settings run the Bi-Wire amp setup..
just wondering if there is a crossover or are these speakers truly bi-wire?? I am unsure and want to make sure I connect them correctly..
The_Nephilim is offline
post #12 of 12 Old 09-12-19, 11:49 PM
willis7469's Avatar
Not familiar with those, maybe I will look later but bi-wire usually just means “buy wire”. The XO in the speaker is still in use and if your doing it with an AVR, it’s still the same power supply so no benefit. Bi-amping with external active XO’s is a totally different thing.
willis7469 is online now
aj , cores , pioneer , sony
