Ohm load of speakers in series? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #11 of 15 Old 05-21-18, 07:21 AM Thread Starter
Oleson, M.D.'s Avatar
TXFlyGuy
Re: Ohm load of speakers in series?
Well, you have to wonder, if dual speaker pairs was a great idea, everyone would do it and it would be a pretty common thing.
There are a few potential problems.
For one, a series connection pretty much cuts amplifier power in half, which is then divided between the two speakers. So, an amp with 100 watts (per channel) at 8-ohms becomes a 50-watt amp at 16-ohms. That is divided between the two speakers, so they’re each only getting 25 watts. Power calculation is bit trickier in your case – you’d probably end up with 12 ohms per channel with both speakers in series, which would theoretically get you something like 75 watts per channel, again divided between the two speakers.
The other issue is that the sound from respective drivers will be arriving at your ear at different times. IOW, with the speakers side by side, the sound from the “outboard” speaker will reach your ears later than the inside speaker. The result is a phenomenon called comb-filtering. You can probably hear it as a difference in the soundstage, or even a strange timbre-shift as you move your head slightly left or right.
Still, experimenting never hurts. You aren’t going to blow anything up – the worst that can happen is that you don’t like it. But hey, maybe you will!
Wayne A. Pflughaupt
Thanks for your input. I do have an amp that is stable into 2 ohm loads, so that is not an issue. My only goal in this "experiment" is to utilize another set of very nice tower speakers (VMPS), that I built from a kit (8 ohm). These would go next to my factory built VMPS towers (4 ohm).
The hope is to increase the soundstage a bit, and perhaps get audio out that may have a bit more overall impact. And...to be able to put the spare towers to good use.
On a side note, these are currently running paired up with a pair of BIC DV-84 towers in another room, creating a 4 ohm load. The DV-84's are much more sensitive, so the volume is a bit more pronounced. But the VMPS has greater bass extension, and this fills out the lower octave nicely.
The comb filter effect is not noticeable, but this is in a smaller sized room.
Oleson, M.D. is offline
post #12 of 15 Old 05-21-18, 04:00 PM
Kal
It'll work if you wire them in series, but not in parallel.
The problem with wiring different speaker systems in series is probably not a matter of impedance load but that each speaker with its particular complex impedance curve will act as a series filter for the other. The resulting sound quality is completely unpredictable.
Kal Rubinson
__________________________________
"Music in the Round"
Senior Contributing Editor, Stereophile
Kal Rubinson is online now
post #13 of 15 Old 09-14-18, 01:29 PM
Kal Rubinson wrote: View Post
And the phase angle will be so grossly exagerated. Never wire speaker systems in series for two reasons.
Main/2nd/3rd System
AVR Yamaha RX-V1800/RX-V1900/RX-V1500
Turntable ProJect Xpression III + Ortofon Red
Cassette Deck Yamaha KX-800U/KX-800U/K-720
BluRay Yamaha BD-S681/Sony UBP-X800/Panasonic DMV-BD30
Media Player Iomega +1TB internal drive/WD TV Live Plus + 3TB USB drive
Display Samsung UN65KU6491 65"/UN55MU7000 55"/UN50MU7100
Speakers Main:PSBImage T-45/400/Alphas, Center:PSB Image 8C/200C/AlphaC , Surround:PSB Image 1B/RBH A600
Subwoofer Rythmic LV12-R/PSB Subsonic 6/5
3dbinCanada is offline
post #14 of 15 Old 09-17-18, 03:53 AM
It should come out to b 6. Why wire this way!
xmc1 is offline
post #15 of 15 Old 09-17-18, 03:56 AM
What r u try n to achieve?...an odd ohm load? If so r u n need of getting the most from ur amp/receiver?
xmc1 is offline
load , ohm , series , speakers
