HT Center Speaker Matching with Front Speakers - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 15 Old 10-14-18, 03:35 PM
Kal
Re: HT Center Speaker Matching with Front Speakers
wtaylorbasil wrote: View Post
As I have responded to theJman in my post 8. Do I need a full range speaker to match?
Answered in Post #9. I use three identical floor-standing full range speakers across the front for L/C/R and smaller floor standers for surround.
Kal Rubinson
__________________________________
"Music in the Round"
Senior Contributing Editor, Stereophile
Kal Rubinson is offline
post #12 of 15 Old 10-14-18, 07:08 PM
HTS Moderator
ajinfla's Avatar
AJ
Agree with Kal the bass loading shouldn't be a consideration. Finding a center speaker with similar drivers and physical layout might be difficult if not impossible. There is a DIY option of finding a single TLS80 and hacking it up into a center. Otherwise, just buy a modern center or small bookshelf with a poly midbass and soft dome tweeter and let your Onkyo do its auto eq setup and see how close a match it can get timbrally. Not the end of world if not perfect match.
AJ
ajinfla is offline
post #13 of 15 Old 10-15-18, 09:25 AM
Kal
Early Spendors used the same HF with Bextrene woofer/mid. Might work.
Kal Rubinson
post #14 of 15 Old 10-15-18, 10:07 AM
Andre's Avatar
Andre
Tech specs on the speakers
Technical specifications
Years manufactured: 1977-1981
Original MSRP: 630 british pounds
Drivers: KEF B139, KEF B110A, Celestion HF1300, Celestion HF2000
Recommended Power: 50-100 Watts
Efficiency: Approximately 85dB depending on tilt control
Crossover: 375Hz, 3.5kHz, 13kHz
Vented, Sealed: Transmission Line (info)
Frequency Response: 20hz to beyond audibility
Dimensions (on supplied stands): 41.75" (H) x 18" (W) x 15.75" (D)
Weight: 37kg each, 45kg with stands
With that info you can look on EBAY UK for a Celestion F48C or a KEF Cresta
Andre is offline
post #15 of 15 Old 10-15-18, 08:29 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
I had a look at the AT-2 and it goes down to very low frequency output. May be I ought to ask a more "fundamental" question. Center speaker handles the speech section and that should be enough with less than 200Hz to may be 2.5KHz. So why do we need a full range speaker. Once I understand this may be I can move on.
The center is known mostly for voices but it does handle quite a bit more than that. Even if all it did was voices males can reach down to the 80Hz range so stopping at 200Hz would lead to a very thin sound.
As I have responded to theJman in my post 8. Do I need a full range speaker to match? Can you help me understand this philosophy?
Ideally you want to match your left and right to the center as the front 3 constitute the vast majority of the soundtrack from traditional 5/7.1 systems. For example, you don't want to have a center with a horn tweeter and left/right speakers with a soft dome tweeter as their voicing wouldn't be consistent. To the best of your ability you want to match the performance, capability and drivers across the front 3.
Given your situation it might be worth considering that phantom center option. In essence it takes the output that would have gone to a center channel and blends it into the left and right channel to create the illusion of a physical center speaker. Since it's unlikely you'll be able to match your current speakers it may a workable compromise.
-Jim
theJman is offline
center , front , ht , matching , speaker , speakers
