Music Speakers - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 13 Old 05-25-06, 08:01 AM Thread Starter
Tommy's Avatar
Tom
Music Speakers
My dedicated HT room will be in the basement, next to the HT room will be my gym. What I would like to be able to do is somehow run some wires from the HT rack into the other room so and hook up some speakers so I can listen to music when I exercise.
The HT installer that gave me an estimate on the HT room quoted thousands for just this. Is it really that big of a job and do I really need a bunch of new components just to listen to a music cd?
I figured besides the wire and couple of cheap speakers that would be all I needed and that the existing ht components would handle the rest.
For 2k I'd rather buy a seperate stero system. Is there an easier/cheaper way of doing this?
Tommy is offline
post #2 of 13 Old 05-25-06, 09:34 AM
mike c's Avatar
mike
Re: Music Speakers
a small radio/CD/tape player
mike c is offline
post #3 of 13 Old 05-25-06, 09:55 AM Thread Starter
Tommy's Avatar
Tom
Re: Music Speakers
Yea thats what I have now and just figured it might be as simple as runing to extra speaker wires & speakers from the ht receiver and playing the cd in the dvd player, yes/no?
Tommy is offline
post #4 of 13 Old 05-25-06, 10:01 AM
jheaton
Inactive
Posts: n/a
Re: Music Speakers
This seems expensive to me, but it depends on what they quoted you for. If your using a receiver that can handle the extra speakers it should be somewhat inexpensive. There is always more questions to be answered though...like do you want to control the system from the GYM? (volume, tuner, cd's) Do you want to operate the GYM as a second zone (ie listen to something different than whats playing in the HT)?
sh
post #5 of 13 Old 05-25-06, 10:14 AM Thread Starter
Tommy's Avatar
Tom
Re: Music Speakers
sh
Yea he started quoted for seperate componets zones receivers cd playes etc... Just working speakers in the gym is fine. Before the workout I can go in the ht room put on a cd and thats it. also it does not have to play music in the gym while someone is watching a movie just one working thing for both rooms
Tommy is offline
post #6 of 13 Old 05-25-06, 10:39 AM
Greg
Re: Music Speakers
There are many receivers out there that do dual zones. There is a thread for a HK 635 in the components forum for a great price. I know my HK DPR-2005 can operate 5.1 in one room and 2 channel in a second room, so I think the 635 can as well. If you need to control the receiver from the gym, you will probably need some type of UHF remote or remote extender that can get pricey. At that point, you may just want to buy a really inexpensive receiver for the gym and a pair of speakers.
GregBe is offline
post #7 of 13 Old 05-25-06, 11:24 AM
JCD
JCD's Avatar
Jacen
Re: Music Speakers
At a bare minimum, you could use the speaker B connection on your receiver to power the speakers in your exercise room. The down side to this is that you'd be stuck listening to the same source as the main HT unless it has a proper dual zone setup. To get this up and running, you just have to run speaker wire from the receiver to your exercise room. If you wanted to be able to use a remote control in the exercise room, you could get some sort of IR repeater.
Now, all that being said, if it were me, I'd probably either get a good boom box OR a separate receiver and CD player.
You can get a very respectable receiver for ~$200 and a CD player is ~$75. Either setup allows you to listen to workout music while someone is watching a movie -- or vice versa.
The only downside is the space taken up by your equipment.. don't know if that's an issue.. but I think it's the most flexible.
JCD
JCD is offline
post #8 of 13 Old 05-25-06, 03:09 PM
jheaton
Inactive
Posts: n/a
Re: Music Speakers
Looks like a simple pair of speakers connected to the "B selector" would be fine then.
post #9 of 13 Old 05-25-06, 04:27 PM
Steve Williamson's Avatar
Steve
Send a message via Skype™ to Steve Williamson
Re: Music Speakers
My Pioneer can run 7.1 in HT and seperate zoned 2 channel to another room with different source.
Just have to select A or B Channel on remote. I have been to so many other installers over here and the equipment they quote for is amazing, one of them, because I wanted to store DVD's on a hard drive, quoted $65000 for a MAX server
Theres always a cheaper option if you research.
Steve Williamson is offline
post #10 of 13 Old 05-25-06, 07:14 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Music Speakers
Yup, looks that way to me, too – and maybe an in-wall volume control at most. Tommy, tell your installer that’s all you want. The speaker wire won’t cost much, so the price will primarily ride on the speakers you choose, and labor.
Wayne A. Pflughaupt
music , speakers
