Speakers for Large Dedicated Theater - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 41 Old 07-23-13, 08:43 AM Thread Starter
Ok,
I am working on which speakers I should be looking at for my dedicated theater. Drywall goes up in a week or so and things will move quickly from there. The room is 18.5'x 30' x 9'. I will have two rows of theater chairs at 11.5' and 17' with bar seating behind the last row. There will be a wet bar in the back of the space. This theater is on my second floor. I do plan on making some acoustic panels after I get the room finished. The screen will most likely be 130" in this room if that matters. I plan on doing 7.2 and wiring the room for 11.2. I have an older Elemental Designs A2-300 that I would like to use as well as my Onkyo 707. I know those aren't the best long term but I hope they are a stop gap for a year or so.
So far I have been looking at a few different DIY options, Chase SHO-10, Ascend Acoustics CBM-340SEs, and others. What do you think I should look at? I would prefer to stay at or under $1K for LCR.
wraunch is offline
post #2 of 41 Old 07-23-13, 09:28 AM
tonyvdb's Avatar
Tony
Re: Speakers for Large Dedicated Theater
Given your going to continue to use the Onkyo 707 and your room is a decent size your going to want to use fairly efficient speakers. Look for speakers that are above 89db and preferably towers not bookshelves. You will also need a decent subwoofer. What is the budget for the sub?
I would suggest two of these Klipsch F-30s and this C-20 centre channel on clearance!
Used is always another good option as well.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 41 Old 07-23-13, 10:38 AM Thread Starter
I am open to using used sets. havent set a sub budget yet.
wraunch is offline
post #4 of 41 Old 07-23-13, 10:44 AM
tonyvdb's Avatar
Tony
For your room a decent sub is a must, I highly recommend at least this SVS PB12 NSD
Home theater:
Living room system:
tonyvdb is offline
post #5 of 41 Old 07-23-13, 10:45 AM Thread Starter
Link is for the Klipsch center. Aren't those Klipsch speakers a little undersized, especially that center?
wraunch is offline
post #6 of 41 Old 07-23-13, 10:50 AM
tonyvdb's Avatar
Tony
Sorry, this sub
Not at all, those speakers are very capable of producing reference levels even in your size room. Particularly if you get a good sub as that takes all the load off the mains.
Home theater:
Living room system:
tonyvdb is offline
post #7 of 41 Old 07-23-13, 12:20 PM
tcarcio's Avatar
TC
I have the Chase HT Sho10 for a center and Pro10's for my L+R and they are very efficient. I have had them for a year now and for the money they are well worth it, IMO. Dale did a review on the Sho10 and their subs that was very positive. You can check it out here...
http://www.hometheatershack.com/foru...-2-review.html Good Luck.
tcarcio is offline
post #8 of 41 Old 07-23-13, 12:20 PM
Charlie
Depending on what you want you might consider JBL pro audio speakers, guitar center handles them new and used and just for pricing purposes I found them online here http://www.idjnow.com/StoreModules/P...-DeID=0--SRCH=
Three of these across the front would work well.
chashint is offline
post #9 of 41 Old 07-23-13, 12:27 PM
tonyvdb's Avatar
Tony
chashint wrote: View Post
Driving those with an Onkyo 707 would prove to be very difficult.
Home theater:
Living room system:
tonyvdb is offline
post #10 of 41 Old 07-23-13, 12:56 PM Thread Starter
Just talked with Craig from CHT and there's a strong possibility I will use his new stuff for my setup.
wraunch is offline
dedicated , large , speakers , theater
