Bi-Amping with Different Watts - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 15 Old 11-15-07, 05:12 PM
Josuah
Re: Bi-Amping with Different Watts
Yes.
Josuah is offline
post #12 of 15 Old 11-15-07, 06:10 PM Thread Starter
Well, that's going to save me a bunch of money. I think that I may try it and see for myself, but from what I've been reading, it doesn't show any benefits unless you use an external crossover.
alexadams77 is offline
post #13 of 15 Old 06-14-08, 07:04 PM
johnG
I bi amp my front speakers for to use as 2 channel stereo in my 5,1 system .However the gain of all my amps is 29 top treble 100 watts bottom 60 watts ,But they have to be the same gain characteristics. ie I use a tag 5x100 amp (one channel used for front treble ) and a Tag F3 series P60 (ie 60 watt for front bass) even though they are 60 and 100 they have the same gain and sound fabulous into my Monitor audio's 8i's. Far better control at high volumes and sound much better all round.
john guest is offline
post #14 of 15 Old 06-15-08, 08:00 AM
M
alexadams77 wrote: View Post
So, are you saying that you wouldn't recommend doing the bi-amping then?
I found bi-amping solved the problem I had with receiver overload. I was driving 4 ohm Polk LSi front speakers with a Pioneer VSX-1014TX receiver. With high volumes during movies when bombs exploded, or with glass breaking, the receiver would cut out at higher volumes. Passive bi-amping using the surround outputs definitely cured that problem for me and I ran it that way for a couple of years.
I subsequently purchased a separate Emotiva LPA-1 amp which was a much better solution.
xcapri79 is offline
post #15 of 15 Old 06-23-08, 04:35 PM
Frosti7
Diffrent phase response would give you different sound, your best bet is to try, but i would use the stronger amp for the woofers instead of the tweeters.
frosti7 is offline
biamping , watts
