speaker batting - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 06-22-14, 08:06 PM Thread Starter
Todd
speaker batting
I have some technics SL101's for my HT (2-way) 6" woofer & 2 1/2" tweeter, there is no acoustic damping in them, would some help? will it tighten up the bass or give it more bass? Also from what I've been learning is 3/4" material is best for speakers, these are just made of some 1/2" stuff, would it be a good upgrade to make some new boxes for them?
toadster is offline
post #2 of 5 Old 06-23-14, 01:26 AM
Re: speaker batting
toadster wrote: View Post
If you wanted to cram in stuff in some poly fiber fill, it might be worth the experiment It's cheap and easy, but I wouldn't expect too much.
As to building new cabinets...I'd probably start over from scratch with fresh drivers with known TS parameters, perhaps a pre-engineered kit. It would be a surprise if the old Technics drivers had any virtues worth building new cabinets for. For example, 60W is light for even entry-level AVRs these days.
gazoink is offline
post #3 of 5 Old 06-23-14, 02:07 AM Thread Starter
Todd
Re: speaker batting
ok. so 60w? is that what my avr puts out?
toadster is offline
post #4 of 5 Old 06-23-14, 08:58 AM
Re: speaker batting
Actually, no idea, since I don't know what receiver you have. Most entry-level units max at 80W, the better ones are at 125Wpc or so.
gazoink is offline
post #5 of 5 Old 06-23-14, 03:11 PM
zieglj01's Avatar
Re: speaker batting
Get some silicone and seal all of the inside of the cabinets, where they
have been glued. Then line some batten to the sides, back and top of the
cabinets. It will make a difference - it will be small - however, that may
be enough of a difference maker for you.
I use to own Technics.
Who or Where, is The Way, Truth and Life?
Speakers - MB Quart VS05, Boston VS260, Snell K7
Subwoofer - Mordaunt Short Aviano 7
Receiver - Tascam PAR-200, Pioneer VSX-30
zieglj01 is offline
batting , speaker
