-   Home Audio Speakers (https://www.hometheatershack.com/forums/home-audio-speakers/)
-   -   Need help deciding between two center speakers (https://www.hometheatershack.com/forums/home-audio-speakers/175088-need-help-deciding-between-two-center-speakers.html)
oDuff 01-17-19 04:32 AM
Hello
I appeal to you because I do not know which central speaker to choose between these two models:
Klipsh RP-404C
Klipsh RP-500C
Their characteristics are quite close.
I doubt that the model with 4 speakers should be better but is the difference really significant for a room of 22 square meters?
Thank you
theJman 01-17-19 07:31 AM
Re: Need help deciding between two center speakers
Because your room is not very large a wide center like the RP-404C might not be the best option. The RP-500C may be a better choice and should provide all the output and detail you would need.
Wayne A. Pflughaupt 01-17-19 09:16 AM
I’m with Jman – the 500 is all most people will ever need!
oDuff 01-17-19 10:36 AM
Thank you very much for your valuable advices
which is more will save me a few cents!
Nicktomp 01-22-19 03:16 PM
I dont know about that... Cause my friend had Klipsch RP-500C and he didnt like it at all. Although I have JBL bar and I love it and he loves it too, so maybe you should do more research? idk check out this guide maybe, these are good ones! https://geeklah.com/best-wireless-su...nd-system.html
