-   Home Audio Speakers (https://www.hometheatershack.com/forums/home-audio-speakers/)
-   -   Went used speaker hunting today at the pawn shops (https://www.hometheatershack.com/forums/home-audio-speakers/21645-went-used-speaker-hunting-today-pawn-shops.html)
the_diyr 09-30-09 04:49 PM
I got a infinity surround speaker for 10 bucks .. Everything works gret the only thing is i need to resurround the woofers .. I found a kit for 29.00 online .. so thats a pretty good deal ... the wood and cover are spotless .. I will get some pics.. The Specs are
Model : RS video black
-::- Frequency Response : 100 Hz - 25 KHz +3dB
-::- Crossover Frequency : 2200 Hz
-::- Sensitivity : 89 dB @ 2.8V -::- Impedance : 8 Ohms -::- Power Rating : 20 - 150 watts RMS into 8 Ohms
-::- Woofers : 5 1/4" [ x 2 ] -::- Tweeter : 1" Ferrofluid Cooled Polycell
-::- Cabinet : Black Ash
-::- Dimensions [ W x H x D ]: 465 x 115 x 120mm -::- Weight : 4.5kg
Only 1 ? the refoam kit says 5 inch and that it will fit my speaker model 902-6416
HMMM so is it a 5inch or 5.25 inch ... Or should I just get new speakers for it ..
The tweet is in mint condition..
Jon Liu 09-30-09 05:59 PM
Re: Went used speaker hunting today at the pawn shops
10 bucks plus 30 for repair kit? Nice!!!
ironglen 09-30-09 06:23 PM
That sounds like a great bargain-say, will those new surround kits bring the woof back up to spec? Which kit are you using/considering? Anyone know which are best/best value?
the_diyr 09-30-09 10:00 PM
5 Attachment(s)
:bigsmile:Ok here it is I have been cleaning the woofers for about 2 hours... One thing that worries me is they say to remove the dust cap and use shims but these woofers it looks impossible to do because the dust caps are flat ..
the_diyr 09-30-09 10:06 PM
Should I try to get the dust covers off are just take a chance and put the surrounds on and be real careful ??? The cover for this that is not pictured is in mint shape as well so if the speakers turn out a little ugly you will not be able to tell ... The woofers are 4 ohms and they were wired in series then too a crossover and the Ferrofluid Cooled Polycell tweeter is in mint shape ... I am really worried about trying to get the dust caps off??? Do I have too shim it and take the dust caps off ?
ironglen 09-30-09 11:08 PM
I've never done a re-surround, but seems to me that shimming would center the voice coil and thus enable the re-surround most accurately. Otherwise, if you glue the surround to the cone first, let dry, then apply the glue to the frame, followed by pushing the surround into the wet glue while the driver is perfectly level, it seems that would be a good method.
Perhaps someone else has done this successfully?:help:
the_diyr 10-01-09 07:53 AM
1 Attachment(s)
Well I decided to remove the dust cover .. it was a slow process but probably well worth it .. I used a little thinner and rubbing alchol and a razor blade .. Took me about an hour to get this one off ..
the_diyr 10-01-09 08:14 AM
After removing both dust caps , I really see the need to shim before putting on the new surround because with out the surround the coil moves everywhere.. And if you are off one MM of an inch you will have to start all over .. so now I am going to shop for the new surround .. I think I am going to go with a woofer rubber surround instead of the cheap foam that was on it originally... More to come
lcaillo 10-01-09 08:14 AM
Sorry I missed this thread. I could have saved you some time. I have done many of these and found that rather than removing the dust cap, I can get more perfect centering by leaving it, and not risk getting dust and debris in the gap. What I do is use a slow drying glue (my favorite is WelBond) and start by gluing the surround to the cone. The slow drying lets me get the centering as even as possible. Once that dries, if you put a weight on the cone (use a smaller speaker) to push it down slightly, it lifts the outer edge of the surround off of the basket, allowing a bead of glue to be run along the inner edge of the basket under the surround. Then release the weight and let the cone rise up. The coil will be very close to centered in the gap if you are careful to place the weight inthe center because of the tension from the spider. Tamp down the outer edge, then as the glue is drying you can move the cone up and down to verify that there is no scraping of the coil on the poles. The slow drying glue lets you center it if needed.
The problem with shimming the gap is that you can get some uneven surrounds or pulling due to glue drying, and still get an off center job. You also have to be very careful not to get dust in the gap.
the_diyr 10-01-09 09:44 AM
OOPs .. I guess if they screw up I could get some Dayton's and throw in there but i am tring to keep it all orginal .. I guess i Could glue the caps back on .. and I have a couple of old cv tweets I could set in the center of the speakers for weight ... I may try the shims .. my biggest problem with these 902-6416 speakers is that they are 4 ohm and hooked in series in the cabinet.. It is a center channel infinity .. And it is hard to find good 5.25 inch 4 ohm home speaker replacements.. Since I have already got the dust caps off should I shim it or just put the caps back on and try it with weight and slow drying glue..?
