HSU Research VTF-3 MK5 HP Discussion Thread - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
 7Likes
post #61 of 67 Old 02-08-17, 11:54 AM
asere's Avatar
Re: HSU Research VTF-3 MK5 HP Discussion Thread
Savjac wrote: View Post
Thank You Asere !!
I do have a noob question though, what is the best way to remove these plugs from the ports. The plug is in there pretty tight and does not want to come out short of using a dental pick or something.
I am not sure. I had the mk4 and I think I had to just grasp it good enough to pull out. Make sure if you use something you don't poke a hole. Sorry I'm not much help.
Sent from my SM-G900P using Tapatalk
asere is offline
post #62 of 67 Old 02-08-17, 01:03 PM
Lumen's Avatar
Lou
My what a nice sub you have!
The better to shake you with!
My what a big driver you have!
The better to pound you with!
My what stuffed ports you have!
The better to perplex you with!
Have you tried a plastic shoehorn? Slide it into the port around the circumference of the plug, then use it as a lever to try and pry the plug out (being careful not to mar the port finish). If it's an issue, try wrapping the end of the horn in something thin but soft, like a napkin.
Savjac likes this.
I try to be as good as my dog thinks I am
Lumen is offline
post #63 of 67 Old 02-08-17, 06:20 PM
willis7469's Avatar
Just turn it up loud enough to blow them plugs out!!!
She's a beauty jack.
Sent from my iPhone using Tapatalk
willis7469 is offline
post #64 of 67 Old 02-08-17, 06:21 PM
willis7469's Avatar
Yes direct will disable the sub out. Stereo should leave it engaged.
post #65 of 67 Old 02-08-17, 07:32 PM
Savjac's Avatar
Jack
willis7469 wrote: View Post
I will have to make sure that Audyssey is turned off for music as the "Stereo" setting does not sound as good as "Direct".
Nope not even close
Good Listening
Jack
"For those who believe no proof is needed for those who don't believe no proof is possible"
Savjac is offline
post #66 of 67 Old 02-08-17, 08:38 PM
willis7469's Avatar
You must have a better room than I. I mostly don't use direct, but I prefer my subs engaged also. A beautiful world indeed!
post #67 of 67 Old 08-25-17, 04:23 PM
How does this compare to the VTF-15H MK2. I am having a hard time deciding. That 15H is quite heavy to be moving around.
thanks
Carlos
ccerezo is offline
discussion , hp , hsu , mk5 , research , thread , vtf3
