All purpose HiFi subwoofer - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 11-23-10, 08:35 AM Thread Starter
jon
Hey all
I don't post very often, but read here daily. I am in the process of slowly putting together a home theater. First component into my house will be the subwoofer. While I save up for the other bits, the sub will become part of my very nice 2 channel rig. The speakers I am currently running are Selah Audio diy kits. They are 3-ways with a 10 inch ported Aluminum Revelator on the bottom. I have loosely measured them in my room flat to mid 30s. What should I be looking at for a sub to compliment what I already have? At this point, I am considering Rythmik F15HP and possibly SVS pb13 Ultra or sb 13 plus. I would like the sub to be available in Canada if possible (I know I will have to import the Rythmik), and my budget is under $2000.
Thanks for your thoughts.
Jonathan
jkrueger is offline
post #2 of 8 Old 11-23-10, 12:32 PM
Banned!
Re: All purpose HiFi subwoofer
Hi Jonathan, if you are looking for a good sub intended for 2 channel and multichannel music as well as movies then I strongly urge you to look at the Martin Logan Depth i as so far I am very impressed with its performance, I also had the Descent i but that will be over your budget but you more or less get most of its bigger brothers performance, I will be doing a review of it shortly so look out for it, and it sits roughly within your budget
recruit is offline
post #3 of 8 Old 11-23-10, 12:52 PM
tonyvdb's Avatar
Tony
I have the SVS PB13U and can say that is is not only a great sub for movies but has a great ability to play musically with no over exaggeration of the "boomy" frequencies. You simply dont know its there but turn it off and the entire depth disappears in music. A sub should be invisible and non directional and the PB13U does just that.
Home theater:
Living room system:
tonyvdb is offline
post #4 of 8 Old 11-23-10, 09:26 PM
Jason
Everybody always recommends the same equipment and subs here, but, honestly for music, I'd recommend a Rel B1. Especially since you're using it for 2 channels and am already measuring flat down 30hz, the Rel offers many options to crossover and/or take over by Neutrik connection where your mains leave off. It's a pretty sweet sub for 2 channel.
I doubt I'll get many backers, but the Rel would work absolutely perfect for your situation. It's also in your budget or under if you get it used of Audiogon.
Jason_Nolan is offline
post #5 of 8 Old 11-24-10, 01:12 AM
Banned!
Jason_Nolan wrote: View Post
People tend to recommend subs that they either own or feel is best for music and I will vouch for the SVS PB13Ultra as it is the best SVS sub made to date barring there new additions which I beleive NO one has heard yet, this is why input from members who own different subs is needed as it gives the OP plenty of options to consider, now I owned 5 REL subs in the past and only 2 were indeed excellent for music but did not offer much when it came to LFE, I cannot comment on the new range but I have heard of indiviuals recommending the B1 before so again it is another option for the OP to consider.
recruit is offline
post #6 of 8 Old 11-24-10, 06:37 AM
Go for the Rythmik. However while it's in your two channel system you may find you don't want to take it out!
talmadge is offline
post #7 of 8 Old 11-24-10, 09:15 AM
I would buy a cabinet and choose your own woofer to put into it. Putting a sub together is one of the simplest of DIY projects. There are many good subwoofer drivers out there and many here have commented on them. You would save maybe $1000 and it will have a very good driver that most likely outperforms anything you could buy for under $2000, most likely more. You don't have to be a woodworker.
Theresa is offline
post #8 of 8 Old 11-26-10, 07:50 AM Thread Starter
jon
Thanks for the response. In the end, I am having a hard time ignoring the savings that would come with DIY. I just don't have very much time these days. I will report back when I have put my money where my mouth is.
Jonathan
jkrueger is offline
hifi , purpose , subwoofer
