MrLoofer's Garage HT Build - Page 12 - Home Theater Forum and Systems - HomeTheaterShack.com
post #111 of 177 Old 05-18-10, 01:42 PM Thread Starter
mrloofer
Re: MrLoofer's Garage HT Build
Oh one more thing, we tested the crown with the rope light (incandescent from Lowes) and the light spill onto the ceiling wasn't that great. Is there a better, dimmable rope light out there that gives a better light spill on a black ceiling?
mrloofer is offline
post #112 of 177 Old 05-18-10, 01:46 PM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Did you apply the 'cheat'? Try tin-foil laying in the tray bottom and wall side to help focus all of the light up and out.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #113 of 177 Old 05-18-10, 01:57 PM Thread Starter
mrloofer
Ooh, not tried that. Does it give a much better effect?
mrloofer is offline
post #114 of 177 Old 05-18-10, 03:16 PM
bpape's Avatar
Bryan Pape
Might still not be as much as you want but it definitely concentrates the light from the full perimeter of the rope up and out.
Bryan
Bryan Pape
bpape is offline
post #115 of 177 Old 05-18-10, 03:29 PM Thread Starter
mrloofer
Thanks Bryan. I also think one of the mistakes we made was putting the crown too close to the ceiling, leaving only a 2" gap. I wasn't sure if the crown should cover up the wall/ceiling seam or not, so at the time we elected to put the crown so the seam is barely visible. When I get home I'll stuff some foil into the molding and raise the rope up a bit so it's not sitting in the bottom of the molding. I'll report back my results...
Cheers.
mrloofer is offline
post #116 of 177 Old 05-18-10, 03:39 PM
mdrake's Avatar
mdrake
mrloofer wrote: View Post
Cheers.
I would be very interested to hear the results. If it works I am going to have to do it to my room.
Matt
___________________________________________
"Half of everything I know is wrong. Unfortunately, I don't know which half."
mdrake is offline
post #117 of 177 Old 05-18-10, 04:22 PM
bpape's Avatar
Bryan Pape
I usually recommend leaving as much gap as the crown extends out from the wall or maybe even more depending on your preference. Get as much foil in there as you can - wall side, crown side, under the rope - as long as you can't see the foil on the wall.
Bryan
Bryan Pape
bpape is offline
post #118 of 177 Old 05-18-10, 08:30 PM
the colors
If I could add my two cents, try mylar it is much better than foil in reflecting light.
the colors is offline
post #119 of 177 Old 05-19-10, 07:35 AM Thread Starter
mrloofer
So last night I tried the foil trick but I really didn't see much difference to be honest. I may try the double up trick and see if that's any better...
mrloofer is offline
post #120 of 177 Old 05-19-10, 05:17 PM Thread Starter
mrloofer
Quick update and a few pics. Hopefully I'll be done with the trim tonight. I got some good clean up done since it's trash day tomorrow so was able to clean up the room pretty good. I also got the shelves painted and installed. Here's the thing with the shelves: I'm happy with how they look but I don't think they'll stand the test of time. I mean, I can only imagine pulling components in and out and scratching the surface of the shelves, after all they are just MDF and painted with a black satin. Does anyone know if there are any companies that can cut to size some decent laminate shelves of some kind?
Fridge was installed, finally! I went through 3 damaged fridges before finding one that was undamaged. The guy at HD said they had about 10 or so that had some kind of damage. They were only $130 each and they look quite fragile. Not sure how long these things will last, oh well!
Pics!
Entrance that still needs trim and touch up.
Rack and trim (wall needs touch up).
Bryan, if you're reading this you can see how close the crown is to the ceiling. I think we put it way to close to get any kind of light displacement from the rope.
mrloofer is offline
build , garage , mrloofer's
