HT planning, basically materials... - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 10-26-11, 08:43 AM Thread Starter
Hi again!
Ok, so I'm planning to renovate my HT! I did a Goggle Sketchup of the room in a very rough way. Here are 2d graphics:
The room from outside (it's above the garage)
https://picasaweb.google.com/pharmap...92316538220882
The size is 11' across and 24' lenghtwise. The vertical walls are 59" high, the 45degrees are 47" long and the ceiling is 86" across.
Here's the room from the inside:
https://picasaweb.google.com/pharmap...93343923940866
The projector will be hanging from the ceiling, roughly 2' behind the couch. There will be speakers in the front corners, sides, rear corners and obviously a center and sub.
I'm planning on putting the AV equipement on the left side of the door.
Now, here's the question: As you can see, there's "rock" on the walls. I though something like this:
http://www.anticoelements.com/16-bet...cultured-stone
Now, will the rough surface be ok to prevent "echo" or will that be an audio nightmare?
Thanks!
Phil
, pictures are not showing. Might a 5-posts thing. I'll try and fix this!
boreas is offline
post #2 of 6 Old 10-26-11, 09:08 AM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Re: HT planning, basically materials...
The rock isn't going to 'give' and absorb like an insulated drywall wall would. It's certainly going to be more lively and 'hard' sounding than standard construction. It's not going to do anything to prevent echo in the space.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #3 of 6 Old 10-26-11, 09:41 AM
SAC
Banned!
SAC
As Bryan pointed out, the irregularities in the surface are simply too small to be 'seen' by the majority of the wavelengths that will be incident upon it.
For the vast majority of the energy, it will be 'seen' as a flat surface.
SAC is offline
post #4 of 6 Old 10-26-11, 09:47 AM Thread Starter
I see... Basically, the faux rock panels are mainly for the looks, not acoustic properties. But if it's going to ruin the sound, might I just be better off leaving the wall as is (well, painting the whole thing deep blue)? Would acoustic panels then be better (and if so, because of the unusual configuration, would I need some on the angled surfaces also)? I'm trying to balance off the "HT experience" factor with the "cool-looking" factor
Thanks!
Phil
boreas is offline
post #5 of 6 Old 10-26-11, 10:05 AM
SAC
Banned!
SAC
It hard to make a blanket statement about exactly what treatment would be most appropriate in a general fashion, as absorption is useful strategically applied to minimize high gain early reflections, and one might use some diffusion to augment the surround returns. (One would want to use the ETC response to better determine the optimal specific locations for treatment(s).)
In a purely HT application (where music is not a significant use), one might prefer to go with a slightly more damped response and allow only the surround speakers to provide the lateral energy return.
Personally I prefer an hybrid approach where the surround info is augmented by a diffuse return, but then I also prefer a mixed use environment... I mention that Only to give you one option that you might consider - not to tell you what to do!
A plain drywall surface would afford the most universally flexible surface, upon which absorption or diffusion could be easily attached, as well as left plain.
And if you are looking for 'cool' treatments, I might suggest that its hard to beat the look of a 1D QRD panel or array.
SAC is offline
post #6 of 6 Old 10-26-11, 10:57 AM Thread Starter
Uhmmm... The more I read (went to the "acoustic" sub-forum), the more I see the complexity of the whole thing... I'll try reposting this in the "acoustic" sub-forum!
Thanks!
Phil
boreas is offline
basically , ht , materials , planning
