Family room TV about mantel setup? can i build a cut out - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 03-05-13, 12:02 AM Thread Starter
Im mounting a TV above the fireplace, if i build out the fireplace somewhat can i put a pocket under where the tv is to store all my components like dvd, cable box etc.... instead of having a shelf at the side?
post pics of someone has done this thanks
wantboost is offline
post #2 of 9 Old 03-05-13, 05:45 AM
hjones4841's Avatar
Silly Girl!
Re: Family room TV about mantel setup? can i build a cut out
I think you will need ventilation for the components. Can you put fans behind the gear? Many people advise against even putting a TV above a fireplace due to heat.
Hug your pet today!
hjones4841 is offline
post #3 of 9 Old 03-06-13, 08:04 AM
MrAngles's Avatar
Height is also a problem for putting equipment under a tv over the fireplace, since the screen will already be too high as it is. In a over the fireplace alcove I prefer to put my equipment behind the tv and use a IR repeater to control it all.
MrAngles is offline
post #4 of 9 Old 03-06-13, 09:50 AM Thread Starter
i dont have room behind. i can only put beside....???
iwont be using the fireplace do i still need fans?
post #5 of 9 Old 03-06-13, 10:09 AM
MrAngles's Avatar
So is there not an alcove above the fireplace? Is there a shelf? What components will you be using? Maybe a picture would help. Ultimately if there isn't an alcove and you'll end up actually mounting the tv on the wall, I'd set up a rack or shelves somewhere else in the room or in a closet.
MrAngles is offline
post #6 of 9 Old 03-06-13, 06:10 PM
hjones4841's Avatar
Silly Girl!
wantboost wrote: View Post
I would put fans in if you don't have openings for heat to escape. These work well and are almost silent:
http://www.buyextras.com/cocofanki14q.html
Hug your pet today!
post #7 of 9 Old 03-07-13, 10:10 AM Thread Starter
where should i put fans so it looks nice and hide them?
1 fan in and 1 out? or both venting out?
post #8 of 9 Old 03-07-13, 08:39 PM
hjones4841's Avatar
Silly Girl!
If you have room behind the gear and can avoid the cables from interfering with the fan, that would be a good place. Blowing in or out won't matter, but if you use more than one I would have them blowing in the same direction. Even on top of each piece of gear will work as long as the equipment is not sealed up in a box. There has to be a place for the heat to exit.
Hug your pet today!
post #9 of 9 Old 03-08-13, 09:09 AM
MrAngles's Avatar
Personally I don't see what difference some little computer fans are going to make above a fireplace if the equipment isn't enclosed. He also said he won't be using the fireplace, so heat really shouldn't be an issue if that's actually the case. Maybe I'm not understanding the setup that is being planned.
MrAngles is offline
build , cut , family , mantel , room , setup , tv
