Room Acoustic Advice - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 15 Old 08-05-13, 02:46 PM Thread Starter
Hey everyone,
I am in the process of building a house. I plan on building a home theater in it. I have been doing months of research and am getting closer to doing actual work. I believe I have a sound acoustic plan but I wanted to confirm with the latest thoughts and theories.
The room is 9'H x 15'9"W x 25' long. The room will use stagard stud construction with insulation, whisper clips and channel, 2 layers of drywall and green glue. Something similar will be done to the ceiling. For sound proofing.
I plan on building a stage (filled with sand) and riser. I will be using an 2.35 AT screen.
The acoustic plan is the following:
Front wall: 2 - layers of 1" linaccoustic or something similar on the front wall. The front corners will have triangles cut from 2" -2'x4' OC703 or something similar going from floor to ceiling.
Side walls: coming out from the front corners 1" linaccoustic or alternative from floor to ceiling for the first 10' or so. (maybe to the riser) From there only go from the floor to about 5' up with linaccoustic. The remainder of the wall will be just be cotton behind some panels or nothing at all behind GOM covered panels.
Back wall: 2" OC703 or something similar with a kraft paper or a FSK facing. Build panels with a 2" airgap making a 4" total thickness and have them floor to ceiling.
Does that plan sound right by today's standards? I have been following multiple build threads all over and it seems to make sense to me.
I plan on using the sofit for can and rope lighting as well as looks. I have read you can put insulation in it as well. If so what do people typically fill it with?
I also read that a riser can be used as a bass trap. Are there any guidelines on how to do this?
Thanks for the advice!
Diesel 48 is offline
post #2 of 15 Old 08-05-13, 03:01 PM
Quenten
Re: Room Acoustic Advice
Actually that will be too much treatment resulting in an overly "dead" room. Only the screen wall should be totally covered, with other treatments placed to cover "measured" problems. The corner traps we know you will need & if you have a riser, stuff that with fluffy insulation (air holes in each cavity, front & back).
Do you have the ability to measure the room before any treatments are applied. That will help us a lot.
Tonto is offline
post #3 of 15 Old 08-05-13, 03:09 PM Thread Starter
The acoustic plan above came from the build thread "Bacon Race" theater on another forum. I believe the the plan came from Bryan Pape. Maybe I misread though. Not sure I will be able to get measurements before starting to treat the room or not. Not sure I can hook up all the speakers first. I definitely do not want an overly dead room. I thought that was the reason treatments were only floor to ceiling for a portion of the room.
post #4 of 15 Old 08-05-13, 03:21 PM
Quenten
B. Pape is our acoustic guru, I have never seen him recomment that much treatment. I'm sure he will chime in soon. The back wall needs to be a bit reflective & some diffusers are/would be appropriate with a couple of absorbtive panels (faced).
While we can assume what common problems exist, it is always nice to know (measure) first, that way we can minimize treatment/cost of treatment.
Tonto is offline
post #5 of 15 Old 08-05-13, 03:22 PM Thread Starter
The back wall called for the 703 with facing, I am sure that was to reflect the higher frequencies.
post #6 of 15 Old 08-05-13, 04:10 PM
Before you choose actual treatment products, get a clear idea of how you want things to sound.
For example, do you want surround information reflecting off the front wall and coming at you from the same direction as your front soundstage? I certainly don't, since I prefer surround information stay in the surround field and not muddy up the phantom imaging between my L/C/R speakers.
So, the front wall (at least between your L/C/R speakers) is a good location for absorption. Same with the back wall: I would cover at least the middle third or half with absorption, since your centre speaker is going to be pointed right at that location.
How about reflections off the side walls? Ipsi-lateral reflections (on the same side as the speaker) tend to stretch out the soundstage and produce imaging past your side walls. Some people like this while others don't. Contra-lateral reflections (on the opposite wall as the speaker) tend to blur directionality. Do you really want sounds intended to come from the left side of your soundstage to also come at you (however subtly) from the right side of the room? I certainly don't.
So, right speaker reflections off the left wall and left speaker reflections off the right wall are good locations for absorption. Centre speaker reflections and nearby wall reflections (right speaker off right wall, left speaker off left wall) are up to you. I personally like the effect, but you should go by your preference.
IF it turns out you find ipsi-lateral reflections too strong but absorbing them too dry, then consider using diffusers at those locations. Again, you'll only know whether you like it or not by hearing for yourself.
Corners are good locations for bass trapping, but you knew that already.
So before committing to actual treatments and locations, figure out which reflections (i.e., from which direction) you want absorbed, which ones you want scattered and which you want left alone (if any). Once you decide on the sound you want, then you'll know which type of treatment to put where.
Sanjay
sdurani is offline
post #7 of 15 Old 08-05-13, 04:36 PM
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Front wall is OK. Corners OK. Side walls, do up to 5' for most of it. Upper portion only enough to capture 2 bounce reflections to the primary seating. No batting in upper portion of the balance. I would prefer to see the side wall 2" if possible - some rooms do not allow for that due to size constraints. We want a well controlled front and reflection zone and a lively more diffuse surround field.
Rear wall and soffits are where you make up ground. Look at the rest of the room, furnishings, construction methods, existing treatment and see where you stand vs a target decay time curve for the particular room and usage. Likely you will have enough mid/high absorption already and be short on lower mid through bass control.
Think thicker (much) on the rear wall with anything from FSK to pond liner to MLV on the rear wall pending how low in frequency you want to start NOT absorbing. You can also do phase grating like our Scatter Plates on top of the absorption to get a little upper mid and high but all the bass and some scattering at the same time.
Soffits are another option if you need more but the rear wall is a place where a lot of bass problems come from.
Bryan
Bryan Pape
Lead Acoustician/Owner
Sensible Sound Solutions
bpape is offline
post #8 of 15 Old 08-06-13, 08:57 AM Thread Starter
Thanks for the information Bryan. Based on the room size I might have room for 2" but will now more once the room is built. I am assuming I can see the first and second reflection points with the mirror trick correct?
What type of insulation is typically recommended for the sofit? Besides some extra conduit and lights my sofits are mainly for looks. I think they will be 16" wide by 10" deep. It is a dedicated room so besides carpet there will be six hometheater lazy boy type chairs. Here is a roughly layout of the room.
post #9 of 15 Old 08-06-13, 09:56 AM
bpape's Avatar
Bryan Pape
You can find the reflections that way. The ones that go off the wall, then the soffit, then to you are a bit trickier
For the Soffit, with that thickness, I would do something like 2" OC703 as the layer that faces the room and then just use fluffy pink insulation for the rest. You can also use all 703 for slightly better performance. Again, pending how low you want to stop absorbing will determine what type of membrane you use on the outside.
If at all possible, I would consider going 6" on the rear wall or even thicker.
Bryan
Bryan Pape
bpape is offline
post #10 of 15 Old 08-15-13, 05:01 PM
RossoDiamante's Avatar
Wow. 6". That will shrink your room really quickly! At what point is the rear wall "far enough" away to be able to discount or at least use minimal absorption? I think I have something like 16' between my listening position and the back wall.
RossoDiamante is offline
acoustic , advice , room
