-   Home Theater Design and Construction (https://www.hometheatershack.com/forums/home-theater-design-construction/)
-   -   Star Ceilings - Painted vs Fiber optic (https://www.hometheatershack.com/forums/home-theater-design-construction/173425-star-ceilings-painted-vs-fiber-optic.html)
NightSkyMurals 02-28-18 05:34 PM
Star Ceiling – Fiber optics vs Painted
A star ceiling is a definite plus for any home theater or bedroom... but what is the best way to go? Should you install Fiber Optics or have the ceiling painted (either by yourself or by a professional)? Well, that depends...
(Mural by Night Sky Murals. Black lights help this painted mural shine brighter when there is light in the room)
https://farm8.staticflickr.com/7499/...1ac19244_k.jpgCal theater with logo by Jeff, on Flickr
(This home theater is in California and was really fun to paint. The owner built the soffit on an angle so the black lights would hit the entire ceiling. That way the stars would show up (fluoresce) throughout the movie. I have a special mixture of paint that I use in home theaters for those who want to have bright stars during the movie. Otherwise, with the lights off... the theater looks like the ceiling has been removed and the stars are more subtle.)
(A Fiber Optic Ceiling (not sure who did this one) with black lights around the edge for looks only)
https://farm2.staticflickr.com/1634/...7a0232c0_z.jpgFiber optic star ceiling by Jeff, on Flickr
Of course my view is going to be a little biased... but I will try to be fair to all three options.
First, lets go over Fiber optics.
They are great to view in almost any light. This is a big “pro” when compared to a painted ceiling. A painted mural acts just like a real night sky and disappears in the light. Fiber optics can still be visible in the light.
When the lights are off in the room... the fiber optics are visible and beautiful. When the lights are on... they are still visible and beautiful. And, you can even make them twinkle.
But, there are some downsides to fiber optics too... The "Cons"
* They are pricey
* They require a lot of extra work to have them installed.
* Holes need to be drilled.
* Wires need to be run.
* If there is no crawl space above the ceiling... then panels need to be prepared, covered, wired and
installed.
* If you don't want to do all of the work yourself.. then you would need to hire someone to do it for
you and they may not have much of a clue what to do.
* You usually get only about 1/10th of the number of stars that a painted mural gives you.
* The holes drilled for the fibers are visible.
* Three, maybe four, different sizes of stars.
* Scheduling a few days, to a week, for it to be installed. Weeks as a DIY project.
But, they ARE nice and the big advantage is that you can see the stars at any time you want basically.
Now... what about the painted night sky murals... DIY and professionally installed?
This is where I can speak with more authority.
Let's start with the DIY option. This option can be both good and bad. Bad if you have no talent as an artist and you just throw up some paint with a paint brush. (I have seen, and painted over, many ceilings where the owner, or their friend, tried to paint the night sky with glow-in-the-dark paint. My first star ceilings were horrible 25 years ago too, when I first started painting them) It looks really easy, but there are definitely some techniques that need to be learned first.
But, if you or a friend are an artist and you want to freehand it... then go for it. And remember... you can always add more stars later if needed. Don't try to go too crazy at first. Paint, step back and look... and then paint some more.
There are also stencil kits that you can purchase on the Internet. Out of the 4 or 5 different stencils that I have tried out... there are two that are much better than the rest. One the less-expensive end is the Night Sky kit by Ursa Major (https://www.ursamajorstencils.com/products/night-sky) and on the high end is a DIY kit by Night Sky Murals (www.NightSkyStencils.com). So, do your due diligence or email me and I will steer you in the right direction for what works best in your situation. If you have more than one or two rooms to paint... you will be sore after painting with the stencil. A good supply of Ibuprofen might be a good thing. Just sayin. :)
"Pros" for the DIY option:
* Cheapest method to get a star mural on your ceiling.
* Usually slightly nicer than the plastic stars.
* You can paint over it if it looks ugly and then try again or call a professional.
* You can claim credit for having painted it.
* If you have to tear out part of your ceiling to fix something up in there... then you can repaint that
area yourself.
* By using a DIY Kit to help guide you... you can have aa very nice star-ceiling and save a lot of money (Two good kits were mentioned above).
The "Cons" to the DIY option:
* Sore neck and back
* It's very easy to create a very ugly mural if you aren't careful.
* It isn't usually as nice as one done by a professional (at least the better ones)
* More unnecessary work to perform where you aren't already proficient.
* There's a good chance that it'll only be slightly nicer than the plastic stars.
* It's frustrating.
* You'll probably glow in the dark for a few days from the paint that gets on you.
Now.. ”The Professional Option”. Are they really that expensive? Here's the quick and easy answer... Some are. Some aren't. And, by the way, I am. (But, I am a lot less than having fiber optics installed)
A quick word about “Professionals” here. There are many people/companies that will teach others how to paint a star mural. One problem is that most of those who are teaching others to paint have never even painted one themselves, or if they have, it was only a handful of ceilings. Usually they are either companies who want to sell their glow paint (so they teach you a method which creates a need for their paint, and they usually are terrible techniques)... or they are just lazy people who see a good idea and try to capitalize on someone elses success by marketing a “Star-Painting Business Kit” themselves. And, as a result, the people they “train” have learned really bad techniques from these non-skilled, snake oil salesmen. So you want to be careful who you hire.
Here are two examples.
This first picture is of a mural that was done by one of the popular companies painting and teaching others to paint these murals. Please don't ask who did this because I won't name them. I show it only to make the point that you need to check around. This picture was taken with a black light on because they probably didn't have a camera with a long shutter exposure. Thus, the background color. BTW... the picture at the beginning of this thread is of one of my murals with black lights on too.
(Another unknown "Professional's" mural)
https://farm2.staticflickr.com/1575/...b9390b35_z.jpgBad star mural 2 by ? by Jeff, on Flickr
This next picture is of a mural that I painted on a really nice ceiling with big beams in it.*
(Mural by Night Sky Murals)
https://farm8.staticflickr.com/7535/...35250540_z.jpgIMG_6410 by Jeff, on Flickr
Having said that... I have seen some work done by other artists that really surprised me because the murals they painted were actually really nice. They were much better than I had expected, after hearing who they'd learned from. But, these murals were painted by people who were already muralists before they decided to add star mural ceilings to their portfolio.
So please be careful when hiring an artist and try to see their work first... or at least have them drop by with, or send you a sample of their work that you can look at. I mean... do you really want to spend all that time decorating your theater room... only to have an amateur come in and destroy your ceiling? There are good artists out there... but you need to search to find them.
As for the cost... You can find people who will throw some paint up on your ceiling for anywhere from $1 to $4 per square foot. My prices start at $11 per sq. ft... and can go as high as $16 per sq. ft. depending on the detail and preparation before I can paint. I'm more expensive than most, but I am fair and the value that you get, I believe, comes out to be a better deal.
OK... here are the “Pros” to having a professional paint the mural:
* The look is Incredible! (When done right, by a true professional)
* Painted night sky murals blow fiber optics away in the dark. (Fiber optics excel in lighted areas) But for
realism... there is no comparison to a painted mural.
* You can have a realistic looking Milky Way in your mural, that has a cloudy look to it and has thousands
and thousands of tiny little stars.
* You can have other deep space objects and the moon added in. (I suggest only having a crescent moon
painted in... because I try to make the mural look like a night sky that you would see from a remote
location on earth. Galaxies and Nebula aren't really visible with the naked eye from earth) But, it is
possible to have all those things with a painted mural.
* You can create the illusion of mountains surrounding the room when the mural is brought down the
walls.
* Ceiling fans and heat registers can be painted too... so they don't become black holes when the
room is dark.
* If you feed some professional painters some BBQ (ahem!) they might even throw in a
shooting star or two.
* Virtually invisible in the light.
* Thousands of stars in the mural... compared to hundreds with fiber optics and DIY options.
* 15 to 25 different sized stars in the murals. This is what creates an incredible 3D look.
* Paint can glow for up to 12 hours, in perfect conditions (the smaller stars will *
fade in about 2 to 4... and the larger stars will glow longer).
* The paint can be made to fluoresce under a black light for viewing during a movie. Not as bright as
fiber optics, but still visible.
* The mural actually changes the longer the lights are off. The mural will look one way when the lights
are first turned out... and totally different 3 hours later.
* The stars seem to twinkle... naturally. Something about the paint and the rods and cones in your eyes
will have you swearing that the stars are really twinkling.
* No smell.
* Can be painted on most finishes
* Usually painted in only a day.
* No need for a crawl space in your ceiling for the mural to be painted. Nor is there the need to add a
false ceiling. Your regular ceiling is just fine.
* Invisible in the light... just like the real night sky. Your room looks like it always has in the light (For darker colored ceilings... some stars will be visible in the light).
The ”Cons” to having a painted mural:
* The cost can get up there, but usually less than fiber optics.
* You need to throw some ribeyes or ribs on the BBQ for some artists. :-)
* You need a fairly dark room for the mural to be seen as intended.
* You need a good fluorescent light source to charge the paint for 10 minutes (Still, plugging in a
black light or two is easier than wiring for fiber optics. Or, if a soffit has power, black lights can be put in there which makes things much easier).
* You could get a bad professional (Do your due-diligence)
* Invisible in the light. This is a “Con” only if you want them to be visible in the light.
Here is what the painted murals look like in the light and in the dark. Again, we do have a special paint (and others might have something as well) that will allow the stars to fluoresce under a black light in a semi-lit room.
https://farm5.staticflickr.com/4131/...816dbb7b_b.jpgSplit Room- NSM by Jeff, on Flickr
OK, I tried to give a fair overview of some different options for a star ceiling. But, whatever option you choose... get a star ceiling. They are so incredibly relaxing and romantic. You've designed everything for the light... do this one thing for the dark. You will be glad you did.
If you have a day-sky (blue sky and clouds) painted on the ceiling... then get a night sky painted on top of that. When the lights are on, the day-sky will be visible. When the lights go out... the night sky will appear. It's very cool!
I've gotten many questions about the murals from people who are building home theaters... and home theaters are probably my number one area to paint in. Bedrooms shouldn't be overlooked. How cool would it be to drift off to sleep every night? Trust me... it's way cool. :)
Please ask any questions that you have and I will try to answer them for you.
If you are in the building stages.. and can still add some wiring for lights... I can tell you where you should have them placed. If you can still add a soffit around your room... I can give you good ideas about how to build that too.
So, if you are considering stars in your ceiling.. ask away and I will try to help you out.
NightSkyMurals 02-28-18 05:39 PM
Re: Star Ceilings - Painted vs Fiber optic
Finally...the pictures are loading! :)
NightSkyMurals 02-28-18 05:51 PM
Test
toothybugs 05-24-18 12:25 PM
Oh man.... That's going to be something I HAVE to look in to!
NightSkyMurals 05-30-18 02:00 PM
LOL... yeah, they're definitely a fun thing to have. Let me know how I can help you, even if you want to do one yourself.
Jeff
toothybugs wrote: (Post 1609274)
NightSkyMurals 05-26-19 07:51 PM
I thought that I'd post a few pictures that I recently painted for customers. Hopefully it will motivate some of you to paint your own Freehand murals(take it slow... these aren't as easy to paint as you might think), get a DIY stencil kit or have a professional paint one for you. They are such a nice addition to a home theater... especially if you prepare for it.
A couple things to do to prepare would be to have a light texture put on the ceiling before you paint it. Even a light knockdown texture will work nicely to hide some of the little bumps. If you have to go with a very dark ceiling color (I've painted many theater room ceilings that had light colored paint and there was very little reflection) on the ceiling, and you want to go with a Flat Black (or other dark color)... then may I suggest a flat paint with enamel in it? It will be easy to clean and won't mark up if you barely touch it. I've started to see a lot more of this paint being used and the upkeep is so much easier and better.
OK, so here are some pictures.
This is actually in a bedroom, but since many theater ceilings are also Tray ceilings... this would look great in a theater.
https://live.staticflickr.com/1955/4...eda616a1_z.jpg
Here's a sideview of a theater ceiling. The Milky Way is very visible because of the Long Exposure picture. It is usually visible, and one of the most requested additions to the murals, and most talked about. I've rarely painted a ceiling without a MW and when people get my kits, I have some instructions that I can send. I've sent more and more... so they are pretty popular with the DIY'ers too.
https://live.staticflickr.com/1914/3...003c2eda_z.jpg
This theater ceiling was really fun to paint. The beams that you see in the picture are actually a couple feet down from the ceiling... so when you're looking at the ceiling, and walking around, the ceiling and beams move at different rates and it's very 3D and awesome!
https://live.staticflickr.com/7493/1...190fa6d3_z.jpg
This ceiling was in a game room/theater room. It may not look like it, but this ceiling is huge... and about 25' up (to the top part). This was probably the scariest ceiling that I've ever painted (out of the thousands I've painted). I remember hugging the lower beams while standing on top of a 16' tall ladder.
https://live.staticflickr.com/7545/1...568bf2f3_z.jpg
This ceiling picture is a composite that a Home Theater magazine used to show the theater and ceiling at the same time. Usually the ceiling and theater aren't visible at the same time (the room needs to be super dark to see the murals).
https://live.staticflickr.com/8677/1...f825c6b5_z.jpg
Here's a Texas mural that it seems the camera caught a split second of the black lights (as they were going out) and that is why you see a lot more blue). I love the look of beams with a mural, but all ceilings are really nice.
https://live.staticflickr.com/7535/1...35250540_z.jpg
On lighter colored ceilings... the murals are virtually invisible in the light. They glow beautifully in the dark.
https://live.staticflickr.com/4131/4...816dbb7b_z.jpg
This last picture is one that a customer painted himself with one of our Full-Ceiling stencils.
https://live.staticflickr.com/65535/...a1299a5f_z.jpg
Hopefully this will give some of you the night sky bug... and you'll consider painting one yourself, or having one painted for you. Either way... there's not much that's more relaxing.
I have some videos posted that will give you some tips if you want to paint one yourself, and others that talk about lighting and other things. They are at www.YouTube.com/NightSkyMurals
deanpegal 06-25-19 06:20 AM
I believe the paint job looks amazing than fiber.
NightSkyMurals 06-26-19 03:51 PM
Hi Dean...
Thank you!! I really appreciate that. But, as I mentioned in the post... both types of star mural has benefits that the other doesn't. And, if you will have a room that get's very dark, then there is nothing better than a painted mural.
Thanks again!
Jeff
deanpegal wrote: (Post 1614158)
NightSkyMurals 08-12-19 01:30 PM
When you give your son carte blanche on making a video for you (with fingers crossed)... and he nails it. :)
toothybugs 08-16-19 09:59 AM
Yup, nailed it :D
