-   Home Theater Design and Construction (https://www.hometheatershack.com/forums/home-theater-design-construction/)
-   -   Pimp My Garage (https://www.hometheatershack.com/forums/home-theater-design-construction/32573-pimp-my-garage.html)
fitzwaddle 08-26-10 04:12 PM
Pimp My Garage
Hi all - thought I'd post some info on the dedicated HT I'm building. If you visit AVS Forums, the title might sound familiar. :clap:
Our house has a 4 car detached garage - has mostly been used as storage (er piles of junk), and for a workshop, and sometimes a car even managed to get in there, but not that often. Since we only have two cars, and after completing our modest remodel, I still didn't have a good space for a dedicated HT, I decided to convert half of the garage into that HT. Have been planning this since before the remodel actually, back in mid/late 2006, but finally swallowed hard and started spending I mean building in earnest a few months ago.
I hired out the basic room construction (new ceiling joists, framing, electrical, insulation, drywall, mud, and even construction of the stage and riser); I'm responsible for paint, screen wall, soffit/rope light tray, columns, acoustic treatments, fabric wall panels, low voltage wiring.
SketchUp model I did some time ago - doesn't reflect a few changes: double door entry, addition of soffit/light tray, rear column location will be in corners:
http://lh5.ggpht.com/_YTd3B8yL8uA/TB...arage4.png.jpg
floorplan (room dimensions: 23' deep to front wall, 21' to false wall/screen; 17' wide; 9' ceilings (except soffit, which drops down 8 inches; seating at 11.5' and 17' approximately):
http://lh5.ggpht.com/_YTd3B8yL8uA/TB...an-new.png.jpg
Here's where is stands at the moment (well almost up to date pics, not quite - finished the basic soffit framing and started screen wall framing) - from the outside (stone circle is a planter box / seating wall, we haven't picked a tree yet):
http://lh4.ggpht.com/_YTd3B8yL8uA/TE...0/IMG_0006.JPG
A few inside pics - before starting the soffit (stage is sand filled, 8" high):
http://lh6.ggpht.com/_YTd3B8yL8uA/TE...0/IMG_0012.JPG
after getting most of the soffit framing done (the soffit in front over the stage will be extended to have a curve matching the stage, and the screen lights will be relocated into that extension):
http://lh5.ggpht.com/_YTd3B8yL8uA/TH...0/IMG_0017.JPG
riser (12", fiberglass filled) - before drywall mudding was done:
http://lh6.ggpht.com/_YTd3B8yL8uA/TB...0/IMG_0003.JPG
entry doors - up over the stone steps on the outside, to the level of the rear riser):
http://lh6.ggpht.com/_YTd3B8yL8uA/TE...0/IMG_0013.JPG
My awesome rack - will upgrade that I think :innocent: - all the gear will be in the closet:
http://lh6.ggpht.com/_YTd3B8yL8uA/TH...0/IMG_0020.JPG
Equipment list / plans:
Pioneer AVX-1120-K - got it
Toshiba HD DVD Player - got it
Blu ray player - TBD, Oppo please? (crossing fingers on the contest) and/or PS3
power conditioner - TBD
XBOX 360 - TBD
speakers - currently B&W DM602 fronts, DM601 side surrounds, CC6 center; will be upgraded, currently thinking of TCA Pro-10s for LCR, Hsu HIW-1s for side / rear surrounds (wired for 7.1)
subwoofer: Velodyne VA-1210 or whatever its called, old - will be upgraded, planning THT LP
projector: Panasonic PT-AE4000U planned
screen: Seymour A/V DIY planned, 136" 2.35:1 or thereabouts
Lighting control: 4 zone Grafik Eye - got it
Seating: row of 4 curved Berklines on riser; row of 3 curved Berklines in front - ordered, waiting until I have carpet in to take delivery.
A/C - split A/C, either LG ArtCool or Mitsubishi Mr. Slim.
Surround speakers will be buried in columns on the side and rear corners.
LCR & subwoofer will be behind acoustically transparent screen on false wall (24" from front wall).
Walls will be fabric covered frames with rigid fiberglass panels (OC 703 or similar) to ear level and below.
Soffit will be stuffed with pink insulation and covered with kraft paper or similar, to add some midbass trapping.
Superchunk midbass traps will be placed in the front corners behind the screen; and in the rear corners within rear surround columns.
That's about all I can think of the moment - let me know if you have any questions, suggestions, etc.
Brad
the colors 08-27-10 05:39 AM
Re: Pimp My Garage
Looks to be a nice setup in a nice spot. One thing I would invest in and it may slip most minds is a smoke detector in the theatre tied in directly to the house smoke detector system. The reason I say this is a freind of mine had a small electrical fire in a setup similar to yours in the garage and had no idea till you guessed it...... it was to late, small fire ===== lots of damage. When the smokes are all together, one sences smoke they all go off.
SurfHB 08-27-10 02:42 PM
Re: Pimp My Garage
Very nice theater! It is coming along great! Keep us posted on with updates.
salvasol 08-27-10 03:38 PM
Re: Pimp My Garage
fitzwaddle wrote: (Post 286710)
Nice room you're going to have there... :T
Any reason why you're moving the columns to the corners instead of the original plan???
fitzwaddle 08-27-10 03:40 PM
Re: Pimp My Garage
salvasol wrote: (Post 287106)
Yes, due to the change to the entry doors - double doors, and offset to one side, so there won't be room (or symmetry) for columns beside the door(s).
fitzwaddle 08-27-10 03:45 PM
Re: Pimp My Garage
SurfHB wrote: (Post 287089)
Thanks, will do!
salvasol 08-27-10 03:46 PM
Re: Pimp My Garage
fitzwaddle wrote: (Post 287108)
Got it :T
Any plans for the grand opening??? :whistling: :innocent:
fitzwaddle 08-27-10 03:59 PM
Re: Pimp My Garage
salvasol wrote: (Post 287113)
Got it :T
Haha, man, way too many things still to work on to even think about that - and I really only get in about 1 day's worth of work on it a week, most of that standing and staring and wondering "hmm, now how am I going to do this...". Fontana is pretty close though... :T
salvasol 08-27-10 04:31 PM
Re: Pimp My Garage
fitzwaddle wrote: (Post 287115)
Yeap... if you need a helping hand :T
Stele 08-29-10 12:42 AM
Re: Pimp My Garage
Nice Brad, very nice.
What do you have planned for the room treatments and placement of the surrounds and subs?
Have you plugged the room dimensions into a mode calculator yet to possible ID potential problems before you start testing/cal?
What kind of wall is it in between the HT and garage? Not that it will matter that much for sound leakage (unless you have someone living in your garage!) just that it will be acoustically different from the opposite wall (which means the calculators will be slightly out).
I bet your already thinking of what the first movie will be!
