Anamorphic Projection Theaters - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #51 of 67 Old 05-24-11, 07:38 AM
SAY IT LOUD's Avatar
MR THX
Re: Anamorphic Projection Theaters
Hi All here is my DIY 2:39 130" screen sorry about the poor quality its from my mobile. when i can work out how to turn the flash off on my camera i will post a clear pic up but for now you can see the size but not the quality.
raZorTT wrote: View Post
Thanks Prof
SAY IT LOUD is offline
post #52 of 67 Old 05-24-11, 08:18 PM Thread Starter
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Very nice job..It looks like the genuine article..
Which prism's did you finish up using?
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #53 of 67 Old 05-24-11, 11:28 PM
MR THX
I used the biz you gave me i think. i look into it and let you know and thanks for your positive coment
post #54 of 67 Old 01-23-14, 02:44 PM
i keep seeing these pics and wanting to go with 2.4 setup over 16.9. can't decide, especially if projector doesn't have a memory lens.
HoosierMizuno is offline
post #55 of 67 Old 01-23-14, 05:09 PM Thread Starter
Prof.'s Avatar
The Mad Professor
If the projector you have or are looking to buy doesn't have auto AR, then an anamorphic lens is a good alternative to manually zooming for the different aspect ratio's..
Prof..
Prof. is offline
post #56 of 67 Old 01-23-14, 05:39 PM
i've heard those are pretty expensive. as far as manually zooming, what exactly does that involve. would i be simply adjusting the lens by turning it somehow. just curious the amount of work that would be needed when someone talks about manually adjusting
post #57 of 67 Old 01-23-14, 06:35 PM Thread Starter
Prof.'s Avatar
The Mad Professor
When you manually change AR's, you would select 2.35 on your remote ( if you're changing from 16:9) and manually zoom the image to fill the screen..and sometimes you may need to refocus..and it's not always easy to just fill the screen and not lose some of the outer image onto the borders..
Generally it's a pain..and particularly if you need to change from 16:9 to 2.35 and back to 16:9 AR during a movie night..
There are more and more projector makes that are now including auto AR's..My last projector has that facility and I'm now able to do away with the anamorphic lens..
Prof..
Prof. is offline
post #58 of 67 Old 03-15-14, 02:46 AM
Good one
tanmoy88 is offline
post #59 of 67 Old 03-15-14, 01:54 PM
Alan Brown's Avatar
Alan
Lightbulb Re: Anamorphic Projection Theaters
HoosierMizuno wrote: View Post
On my projection system, it takes less than 30 seconds to adjust between aspect ratios. That includes adjusting the zoom control ring, vertical lens shift knob, and moving the drapes for masking. Focus is stable when zooming on my projector.
Vertical lens shift range will vary, depending on projector placement. None at all is needed if the lens is located perpendicular to the vertical center of the screen.
The wall behind the screen should be painted black or very dark. Black bars on letter boxed Blu-ray Disc movies will project onto the wall above and below the screen, which can be distracting if the black levels on the projector are not good enough.
The lower cost JVC D-ILA projector model still has excellent blacks, plenty of motorized zoom and shift range, plus lens memories. Last I checked, the less expensive Panasonic LCD projector is similarly enabled. The Epson line may also include a candidate.
Best regards and beautiful pictures,
Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
Alan Brown is offline
post #60 of 67 Old 07-22-15, 11:01 AM
mjg100
Room is 11'-6" x 13'-6".
Have a 9' wide 2.40 curved AT masking screen with Screen Excellence EN4K fabric.
Projector is Sony VW600ES
A-lens is Prismasonic HD6000 with powered slide
Viewing distance is 9'-6"
Room has black walls, black ceiling and black floor. Have black velvet curtains from floor to ceiling on side walls from screen wall to seating. Will see about hunting up pictures later, since the pictures are stored on another computer.
mjg100 is offline
anamorphic , projection , theaters
